TOS 6.0.650 (X86) is Released for Update
scheppi2003
Germany
Re: TOS 6.0.650 (X86) is Released for Update
Post by scheppi2003 »
Thanks, still did not see it. It says MAPL0303V16, but V17. However, I can simply download it and install it manually, right ?
On the other hand, I do have currently a degraded TRIAD, since I had a HDD failure. Shall I wait with the UG until the Raid is repaired or go ahead with the UG and install the disk,when it arrives later today ?
I think it means V16 through to V22. (or whatever that last number is).
F5-221 TOS7.0.1188 - 4x4TB (Ironwolf) Traid
F2-424 TOS7.0.1188 - 2x500GB nvme (P3) Traid, 2x6TB HDD (HGST) Traid
F2-221 TOS7.0.1188 - 1x3TB Ext4, 1x4TB Btrfs
F2-425+ TOS7.0.1188 - 2x500GB nvme (P3) Traid, 2x6TB HDD (EXOS) Traid
scheppi2003
Germany
ok, thx Gremlin. How about the second part of my question. Would you recommend running the upgrade with a degraded Triad or wait for the new HDD ?
TMLila
Post by TMLila »
scheppi2003 wrote: 20 Apr 2025, 00:51 ok, thx Gremlin. How about the second part of my question. Would you recommend running the upgrade with a degraded Triad or wait for the new HDD ?
Hi! Your RAID is currently in a degraded state due to a failed hard drive. Forcing an upgrade in this condition may result in upgrade failure, data corruption, or system crashes.
We recommend replacing the faulty drive first before proceeding with the upgrade.
