How to manually install 3rd Party Apps and the list with available apps
Re: How to manually install 3rd Party Apps and the list with available apps
I don't use all these apps, ping me when there are updates available and will do it when possible.
powerQ
Singapore
Post by powerQ »
outkastm wrote: ↑29 Jan 2023, 18:33 I don't use all these apps, ping me when there are updates available and will do it when possible.
Is it possible to add Tailscale to your app list? Thank you so much!
powerQ
Singapore
Post by powerQ »
{L_BUTTON_AT}outkastm
I found the reason, the search feature on your website is only post option enabled by default, when I search for tailscale, i need to enable other options, or there will be no result found. If the download is enabled by default that will be great.
If you go to "Apps" tab you can filter directly on desired app
powerQ
Singapore
Post by powerQ »
I am sorry for that, but i can't delete my thread now. Can the forum admin help me delete my thread?
Thank you for your reply, I will try again the new version.
lrotk
Post by lrotk »
Hi @outkastm, please, could you be so kind to develop a version of MyMediaAlexa that supports TOS4 x86? Thanks.
TJ27sk
Post by TJ27sk »
Hi @outkastm, i want update filebrowser and docker to new versiom for TOS4 arm.
Manually, via ssh, overwritten applications work.
How can I pack them into a tpk file?
Manual (app-pkg-tools-main) only for TOS5
loltroll3rd
Post by loltroll3rd »
I never get an email with my login details? used different email providers but non get sent
I will check this issue
