TOS 6.0.650 (X86) is Released for Update
Arendatr
Re: TOS 6.0.650 (X86) is Released for Update
Post by Arendatr »
TMzethar wrote: ↑14 Apr 2025, 19:35 We suspect that this might be due to the sleep setting on your USB box.
Please use the following instructions to determine the directory of your own USB drive:
This is not a USB drive, but a UPS
sianderson
Post by sianderson »
Arendatr wrote: ↑14 Apr 2025, 00:54 The USB connection to the F2-423 breaks every hour. I have to pull out and plug in the USB cable.
mine seems to remain connected (yes i lose the icon from the right hand side) but if i go to the file manager and select USB device it shows and kicks it back in, however i did spot that suddenly a few days ago it was named usbshare_sdb1 when previously it was usbshare_sdc1
therefore my TFM backup tasks stopped working, and the only way to correct this was to delete the tasks and re-set them up as you cant change the destination once it has been created, so that would be a bit annoying if it keeps on changing its name, luckily its only 1 part of my backup system
F2-424 TOS 7.0.1341
F2-423 TOS 7.0.1341
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
danx
Japan
Post by danx »
Please improve the problem that qBittorrent does not work
I'm in trouble because it doesn't work with 6.0.650
danx wrote: ↑15 Apr 2025, 14:04
No related issues have been observed at this time. It is recommended that you contact technical support to assist in identifying the problem.
Arendatr
Post by Arendatr »
upsctl start
Arendatr wrote: ↑16 Apr 2025, 02:12
Are you saying that this command can also achieve the effect of unplugging and replugging the USB cable?
jawiler
Post by jawiler »
TMzethar wrote: ↑16 Apr 2025, 13:57
Just tried it, and USB power is now recognized. Thanks!
Lex
Post by Lex »
Lex wrote: ↑09 Apr 2025, 17:52 Can`t turn on media index.
"Can`t create media index"
I can fix this error.
In the log file /var/log/mediadb/mediadb.log
I see strings...
2025-04-11 13:12:43.524 GMT [8161] LOG: invalid value for parameter "TimeZone": "Europe/Moscow"
2025-04-11 13:12:43.524 GMT [8161] FATAL: configuration file "/Volume1/@system/media/pgsql/postgresql.conf" contains errors
In config file/Volume1/@system/media/pgsql/postgresql.con I change all "Europe/Moscow" to "UTC" and media index is start.
F4-423
scheppi2003
Germany
Post by scheppi2003 »
I am not sure if I am posting here correctly, but I would like to know if my F4-421 is eligibable for TOS 6. My bios is MAPL03003V17, which is not mentioned in th BIOS, which can not be upgraded, but also not in the BIOS version you can upgrade. Nevertheless, when I do check for upgrades, it shows, my TOS 5.1.145 is the most recent version. Thanks for the help
scheppi2003 wrote: ↑19 Apr 2025, 23:12
You need to go here: viewtopic.php?p=39506#p39506
Your bios is included.
