TOS 6.0.530 Official Version Released
Re: TOS 6.0.530 Official Version Released
adam12345 wrote: ↑15 Nov 2024, 20:03 i reckon this is a beta cause i don't see it on the website download list
how safe is it to download it without backing your data you think ?
You are posting in a thread that announces that 6.0.530 is an official release {see Title}. It also advises
that it is available for specific models and levels of version progress.
So {if as I presume based on other posts} you have a 424 model and you have progressed to 5.1.145 you
would be able to follow the instructions in Post #1 of this thread.
Subsequent updates should be available via the Control Panel update channel.
You are still cautioned to read release notes (in the Updates thread here) as they become available for
each subsequent version.
It is as safe to update this as most other operating system. In other words = :!: Backup your data and follow the instructions :!:
Nothing can be assumed.
Frustrated Beta Tester!!!
adam12345
Israel
Post by adam12345 »
after i upgraded iv noticed that my network bond is not working (the + icon is grayed out)
worked like a charm on version 5
adam12345 wrote: ↑16 Nov 2024, 00:44
The icon is greyed out if a bond is configured. I have mine configured as Active/Standby (since I have a slow connection on Lan2) and that has
updated ok without apparent issue. You could try deleting the bond, checking that both interfaces are working individually and then resetting the bond of your choice.
adam12345
Israel
Post by adam12345 »
it was indeed configured but on the control panel - network but it is gone now
Bad IP address on lan2. That address is a nic default for an unassigned IP (ie not fixed and not getting address from dhcp). Someone has reported a (similar?) problem with IP address under 6.0.535.
zonatar
Italy
Post by zonatar »
Sorry but just a quick question, i buy a m.2 256gb to install the tos6 on it, i have a f4-424 with 5.1.131, it's better to pull out the hhd from the nas and install the tos6 with the m.2 memory on it and then put on the hhd, or install the m.2 and run the update with the hhd on the nas?
adam12345
Israel
Post by adam12345 »
Gremlin wrote: ↑16 Nov 2024, 01:10 Bad IP address on lan2. That address is a nic default for an unassigned IP (ie not fixed and not getting address from dhcp). Someone has reported a (similar?) problem with IP address under 6.0.535.
k i configured static ip address and then the bond, weird it didn't get dhcp
seems to be working now, thanks for the help
seezee
Post by seezee »
Trying to install on an F4-423 running TOS 5.1.67. File uploads and installation start, but ends with error "Tips: Failed to update"
I have plenty of room on my disks, so storage space is not the culprit.
seezee wrote: ↑16 Nov 2024, 06:25 Trying to install on an F4-423 running TOS 5.1.67. File uploads and installation start, but ends with error "Tips: Failed to update"
Pretty dumb. Read the first few lines of post 1 in this thread.
seezee
Post by seezee »
Gremlin wrote: ↑16 Nov 2024, 06:37
D'oh! I misread my version as 5.1.167.
