TOS 6.0.500 Official Release
abs1ck
Re: TOS 6.0.500 Official Release
Post by abs1ck »
TMRyan wrote: 23 Sep 2024, 22:03
adminsanek wrote: 23 Sep 2024, 03:31 I agree, the same problem with access rights to shared folders, plex and qbittorrent
If you have lost permissions for the "abc" folder under the "public" directory, you can try executing
smbrichacl /Volume1/public/abc -I allow
in the Terminal. Then, try editing the permissions again, and make sure to check the option to inherit permissions. We will work on resolving this issue as soon as possible.
It doesn't help. I still can't change access. And after this command, some of the containers also stopped working :(
Lex
Post by Lex »
TMRyan wrote: 23 Sep 2024, 21:40
Lex wrote: 23 Sep 2024, 20:33
If you are unable to set permissions for the "abc" folder under your "public" directory, you can try executing
, and then attempt to edit the permissions again. While editing, you can select the option to inherit permissions. We will work on resolving this issue as soon as possible.
It`s help me.
But if folder have owner 'guest', it`s not work. If change owner to 'root' user, i can change access right.
F4-423
abs1ck
Post by abs1ck »
All folders where the `www-data` user receives IO error and I can't do anything with them.
abs1ck
Post by abs1ck »
I was able to access folders that issue IO error in this way
chown yourusername:www-data /path/to/directory
jpeckinp
Post by jpeckinp »
abs1ck wrote: 23 Sep 2024, 22:16
Same.
Current System:
F4-424 Pro
40TB storage.
TOS- 7.0.0746
abs1ck wrote: 23 Sep 2024, 22:16 It doesn't help. I still can't change access. And after this command, some of the containers also stopped working :(
Could you please provide us with information about your containers? You can try executing the above command to modify permissions for multiple configuration directories. Then, revisit the control panel or file manager to set the permissions,when setting permissions, make sure to check the option to inherit permissions. We will release a new version to fix this issue as soon as possible.
Lex
Post by Lex »
jpeckinp wrote: 24 Sep 2024, 06:47
Same.
Try change owner. For "root" user, for example.
F4-423
We apologize for the inconvenience caused by an inadvertent code modification by our technical team, which led to issues in the permission module. Our testing team also missed these defects during verification. We will address these problems promptly and release an update soon.
DanielB
Post by DanielB »
TMRyan wrote: 23 Sep 2024, 22:03If you have lost permissions for the "abc" folder under the "public" directory, you can try executing
After fixing it, it still gets reset. It seems kind of random but one trigger seems to be accessing or doing some kind of operation within a folder?!
For instance, having run the command you suggested, I was able to reset permissions for a specific user for the whole shared folder tree with the 'Replace' checkbox enabled, and it seemed finally I had this fixed, for that user. Testing, I used TNAS Mobile app on my phone and logged in with user 'User1', tapped on the Files icon and then browsed to "\TNAS\Photos\User1\Wildlife". I tapped on a file and then swiped through images in the entire folder- great!! I then downloaded 2 photos from this directory on the TNAS to my phone - great!! Then, I tapped on the breadcrumb navigation at the top to go up 1 folder ("\TNAS\Photos\User1") and saw the directory listing as expected. I decided to tap on "\TNAS\Photos\User1\Places" but instead of it loading, I see "no valid data" on a blank background. I navigate back to "\TNAS\Photos\User1" and see the directory listing. I navigate back to the "Wildlife" folder and also now see "no valid data". I go back and enter "\TNAS\Photos\User1\Cars" and can view all of its files. I go back and test another subfolder, it's ok too. I try "\User1\Wildlife" again, still "no valid data". I try to go back to "\User1" and no it says "no valid data". None of the "\User1" subfolders can be accessed now. Then, a minute later, they can... but not the "Wildlife" folder.
I opened Control Panel->Processes on my computer and watched as the 'setafcl' command randomly appeared at one point and apparently reset some more permissions. But I could not get it to happen again on demand.
F2-424 w 1x 250GB WD SN580 Blue NVMe (TOS6.0.519) + 2x 4TB WD Red Plus 3.5"HDDs
jpeckinp
Post by jpeckinp »
TMroy wrote: 24 Sep 2024, 21:15
Good to hear, Thanks
Current System:
F4-424 Pro
40TB storage.
TOS- 7.0.0746
