Please double check your network connection, slow network might be the reason to cause the issue.
TOS 7.0.0408 Beta (X86) is Released for Update
Re: TOS 7.0.0408 Beta (X86) is Released for Update
But I only need that, if I will be using the ssd to boot, right? If I change to HDD again the OS, that boot order change is useless, correct?
Please enter BIOS again and modify boot option #1 as HDD if you need to boot from HDD.
Update: I have deleted and rebuild storagepool and volume numerous times, but after a reboot the problem persists.OttO1916 wrote: ↑12 Mar 2026, 20:40Will give it a try. Thanks!!!Gremlin wrote: ↑12 Mar 2026, 09:32It can sometimes happen that just 'removing partitions' does not always do enough. Search "superblock" on this forum. The long-winded fix, typically, is a secure wipe (writing 'zeros and or ones' across the drive). Other methods may depend on what tools you have available and access to the drive in question. {I usually use a 3rd party partition manager on Windows as I have an 'old-fashioned' desktop with drive caddies available.}
One last delete/rebuild giving it a different name (was "StoragePool2" now "StoragePool 2"), and everything works fine!!
Luckily no need to cumbersome erase the disk
F5-221 - TOS7.0.1298 - 5x4TB TRAID - 1x4TB Single USB - 2x4TB HwRAID1 USB
F2-221 - TOS7.0.1298 - 2x3TB JBOD - 1x4TB Single USB
It`s local network. NAS connect to router by 1000mb/s, notebook connect to router by WiFi 5 GHz
F4-423
We understand that your wired network bandwidth is sufficient. However, regarding Wi-Fi, the 5GHz band is merely a frequency range and does not necessarily mean faster actual speeds. We recommend conducting several read and write tests in practice.
If i copy large file by NFS from HDD, actual speeds ~110 MB/s
F4-423
Thank you for conducting your network speed test and providing the results. We have confirmed that your network connection is functioning correctly. Since network performance has been confirmed to be normal, the root cause of your initial problem may lie elsewhere, such as specific file system configurations or other system settings that require further investigation. If your TOS system version is 7.0.0408, you can try updating to TOS version 7.0.0427. If the problem persists, I recommend scheduling remote technical support.
How to schedule remote technical support?
Please visit the TerraMaster official website (https://www.terra-master.com/) and use the "Online Chat" function to contact our customer service staff. Please describe your problem in detail and request to schedule remote technical support. Our engineers will connect to your device, conduct a comprehensive check, and determine the specific configuration or system problem that needs to be resolved.
