TOS 7 Insider Preview Program
rfbjr
Re: TOS 7 Insider Preview Program
Post by rfbjr »
If you were/are a member of the Inside Preview, when the "Beta" is released, can the beta release be installed "over" the current inside version? Bottom line would we need to start from scratch. Yes everything is backed up. :)
F4-424 Pro (x2) at 7.0.1298
rfbjr wrote: ↑11 Dec 2025, 00:41 If you were/are a member of the Inside Preview, when the "Beta" is released, can the beta release be installed "over" the current inside version? Bottom line would we need to start from scratch. Yes everything is backed up. :)
Users running the inside preview version can directly upgrade to the beta version that we will be releasing soon. Stay tuned!
JAW
Post by JAW »
Yesterday the TOS 7.0.0287 update arrived over the air. There are no Release Notes for this version. Could you tell me what's new in it?
JAW wrote: ↑12 Dec 2025, 17:15 Yesterday the TOS 7.0.0287 update arrived over the air. There are no Release Notes for this version. Could you tell me what's new in it?
Fixed a few UI and language errors.
Klaus3845
Post by Klaus3845 »
I checked the connection of SONOFF Zigbee 3.0 ZB Dongle-M with Home Assistant 2026.2.2 on F2-424, works fine. TOS 7.0.0299 Now you can use my TNAS as a smart home server! Thanks!
Ukey
Poland
Post by Ukey »
I’m having problems passing the Sonoff Zigbee usb coordinator through to a virtual machine with Home Assistant. In general, I can’t pass through anything connected via USB to any virtual machine. I’m running version 7.0.0403.
luismartin
Post by luismartin »
Does TOS version 7 allow file sharing without using the very slow TNAS.Online intermediary server via a DDNS link? In version 6, the only cumbersome way was to edit each shared file individually, replacing TNAS.Online with my DDNS. So my question is... does TOS 7 allow to automatically select my DDNS for file sharing?
luismartin wrote: ↑24 Feb 2026, 21:16
Yes, custom sharing links are supported. You can specify a DDNS link instead of a TNAS.online link.
luismartin
Thanks to support.
MikeZhang
Re: TOS 7 EMBY
Post by MikeZhang »
bladi3990 wrote: ↑05 Mar 2026, 08:59
We installed Emby 4.9.0.72 under TOS 7.0.0408 and it works without issue, it's recommended to update to the latest TOS7 version and install Emby from TOS app center.
