TOS 6.0.650 (X86) is Released for Update
TMnick
Re: TOS 6.0.650 (X86) is Released for Update
Post by TMnick »
Lex wrote: 09 Apr 2025, 17:52
I apologize for the issue you encountered. I'm not sure if the problem still persists. You can try restarting your device to see if it resolves the media indexing failure. If it still doesn't work, please contact customer service to schedule a remote session with a technical engineer to assist you.
jositodc
Spain
Post by jositodc »
TNAS F2-221
TOS: 6.0.650
Hello:
Since TOS version 6, it's been happening to me that the scheduled startup I have always shuts down at the specified time, but never turns on. I have to do it manually.
Excuse my English, it's from Google Translate.
TNAS F2-221 / 6.0.783 8-)
GevinKe
Post by GevinKe »
jositodc wrote: 11 Apr 2025, 19:00 TNAS F2-221
TOS: 6.0.650
Hello:
We sincerely apologize for the inconvenience caused. We are aware that the scheduled power on/off feature may occasionally fail to take effect. This issue is already on our radar and will be addressed in the upcoming version. Thank you for your patience and continued support.
OttO1916
Netherlands
Post by OttO1916 »
Same issue here. I just gave up, and stuck a fingerbot on the power button. Problem solved...
F5-221 - TOS7.0.0765 - 5x4TB TRAID - 1x4TB Single USB - 2x4TB HwRAID1 USB
F2-221 - TOS7.0.0765 - 2x3TB JBOD - 1x4TB Single USB
GevinKe
Post by GevinKe »
OttO1916 wrote: 11 Apr 2025, 21:58
We will resolve this issue as soon as possible in the upcoming version. Thank you for your understanding and support.
Arendatr
Post by Arendatr »
The USB connection to the F2-423 breaks every hour. I have to pull out and plug in the USB cable.
Murrayb
Post by Murrayb »
I get an error message when I try to download the update from within Control Panel > System >Update that tells me to manually download it, but I cannot find the download. Where is it on the site?
crisisacting
Post by crisisacting »
Murrayb wrote: 14 Apr 2025, 02:41 I get an error message when I try to download the update from within Control Panel > System >Update that tells me to manually download it, but I cannot find the download. Where is it on the site?
Most of the newer TOS 6.× builds are not available for direct download.
Arendatr wrote: 14 Apr 2025, 00:54
We suspect that this might be due to the sleep setting on your USB box. You can verify this guess and resolve the issue by creating a custom schedule to run every one and a half hours with the following command (example):
ls /Volume1/@usb/usbshare_sdb1
Please use the following instructions to determine the directory of your own USB drive:
findmnt
df -h
Since the system only supports repeating tasks every hour at minimum, you can set two tasks half an hour apart to read the USB drive every half hour.
crisisacting wrote: 14 Apr 2025, 16:01
You can download the installation package from the download center. Then, you may find that there are no TOS6 builds available for your specific model. This is to prevent users with older versions, who may not read the instructions, from mistakenly using an incompatible version and encountering issues. If you are certain that your NAS can install TOS6, you can obtain TOS6 builds from the download list of other models.
