I'm experiencing issues with my TNAS F4-424MAX running TOS 6.0.648. The problem started after I deleted files to free up system space on the limited 8GB system partition. Now I'm getting a persistent "502 Bad Gateway" error when trying to access the main TOS web interface (both via TNAS.local and direct IP address).
Current situation:
- Full SSH/terminal access via Putty works perfectly
- All Docker containers and their web interfaces function normally
- I Can create and manage Docker images/containers via command line
- All data volumes and storage appear intact
Troubleshooting attempted:
- Followed all support team suggestions
- Reinstalled nginx/1.21.0 from /etc.default
- Attempted reinstall by removing all disks but received "no disk detected - please install disk(s)" error)
-I have downloaded the latest update and reinstall files which are on
I need assistance in the following areas:
1. Is there a way to repair/reinstall just the TOS web interface through SSH terminal?
2. If not, is there a procedure for complete TOS reinstall via a SSH terminal that preserves my data and Docker setup and existing backup data volumes?
3. Instructions for rebuilding/repairing the boot disk too
Critical concern: Will a complete reinstall preserve my volume data? Previous TOS versions warned about disk reformatting during reinstall.
I'd appreciate any guidance on resolving this issue without losing my current configuration to data on the volumes setup.
Has anyone in the community encountered a similar issue or found a way to repair TOS without reformatting disks or losing data? I'd greatly appreciate any insights, tips, or experiences you might be willing to share - especially if you've managed to recover from a similar situation!
Thank you for your help! I'm trying to resolve this without losing my current data and configuration.
