TNAS mobile 3 Beta is released for testing NOW!
- LewisFletcher15
Re: TNAS mobile 3 Beta is released for testing NOW!
TNAS mobile is applicable to Android 8.0 and above mobile phone systems. This means that if you have an Android mobile phone with version 8.0 or higher, you should be able to use the TNAS mobile app. It is important to note that the compatibility may also depend on the specific device and its hardware capabilities, so it's always best to check the app's requirements before downloading it.
- dkaratasos
I checked on Google play and I still see the tnas 2 version there .
Where can I get the tnas3 version that is not beta ?
Thanx !
Thanx !
TMLyy
You can find it when you search tnas mobile 3.
- dkaratasos
No. I tried that.
Gives only the version 2
- crisisacting
- Silver Member
Tell me, does caching of thumbnails work?, or is it not there? At each launch, it feels like a new load from the nas. If not, is it planned? f2-223, xiaomi 13, android 13 (I apologize for broken English)
{L_BUTTON_AT}rugaroo
Generally speaking, TOS generates thumbnails for new images, which are also obtained when accessed on the mobile end. The situation you are encountering may be that the thumbnail has not yet been generated on TOS, or the network connection speed is slow.
{L_BUTTON_AT}TMzethar
Thumbnails are taken from the tos system, without local caching to save space on the phone and ensure that the latest thumbnails can be loaded.
TNAS mobile 3 app for iOS keeps crashing for me
