[ apache24 (PHP 7) ] Web Server
jositodc
Spain
Re: [ apache24 (PHP 7) ] Web Server
Post by jositodc »
I add, this tells me the Nextcloud error.log
TNAS F2-221 / 6.0.783 8-)
jositodc
Spain
Post by jositodc »
{L_BUTTON_AT}outkastm
Nothing, I haven't been able to get nextcloud to show me the valid certificate, I don't know exactly if I'm missing something in Apache or Nextcloud. But Apache now works correctly, any help?
Thanks again and greetings.
jositodc
Spain
Post by jositodc »
Achieved access via secure ssl.
Summary:
-Download Docker from the store.
-Generate a file called docker-compose.yml from Windows Notepad, following the instructions on the nginx proxy manager website.
-execute it as indicated in its manual on the web.
-Have a DDNS for example duckdns.org.
-From the Proxy Manager gui, generate a domain and associate it with the internal IP of the nextcloud, fill in the duckdns.org data that we have.
-Generate an SSL certificate that we must copy to our NAS where we had the previous terramaster one, then in the program's httpd-ssl.conf config indicate the path of the certificate and the key.
-With this, we now have our Nextcloud server running via SSL.
If you have any questions, let me know about this.
pridakon
Post by pridakon »
Hello! I Have F2-424 TOS 6.0.507
Installed Apache apache24 TOS5 2.4.57.0 x86_64, but can't open app.
As fact, i've been logged in as admin account. What can i do with my problem? Can you help me?
Apache4 is not ready for TOS6 > 6.0.420. Please wait for app updage
npclive
Post by npclive »
Hello. In the description of the Apache server settings it is indicated that it is possible to connect PHP 8.0 and higher. But in fact there is only module 7.4. Will it be possible to connect PHP 8.0 modules and newer versions?
