Instructions for Adding HDDs to RAID
TMlinda
Re: Instructions for Adding HDDs to RAID
Post by TMlinda »
CathyW wrote: ↑21 Mar 2025, 19:58
Yes, you can follow this instruction to add HDDs.
tnasuser01
Post by tnasuser01 »
Hi fellow TNAS users,
So I just added a new M.2 disk,
to the storage pool,
However, when I go to create a new volume from an "existing storage pool", it only shows the 1 drive's capacity, i.e., 2TBs instead of 4TBs?
Is this correct because it is configured as a TRAID drive ? Therefore, even though there are 2 2TB drives (4TBs total), the volume only has 2TBs available because the 2nd 2TB is for redundancy ? Thank you for any help.
TNAS User
Yes, that's correct - You can think of Traid as raid 1 when using 2 drives.
Frustrated Beta Tester!!!
tnasuser01
Thank you very much Gremlin for your prompt response. It is much appreciated.
jehuty
Spain
Post by jehuty »
I assume it's easier to increase a volume in TRAID if it's empty or half empty. Is this correct?
I have a 4x 8TB TRAID and I'm moving to 2x 16Tb and 2x 8Tb TRAID.
Thank you.
jehuty wrote: ↑16 Jul 2025, 18:38 Hi,
Thank you.
After you move to 2x16TB and 2x8TB:
In case of normal RAID5, the capacity remains 24TB until you replace all 8TB with 16TB.
On TRAID, the 2 extra 8TB capacity of the two 16TBs can be formed into a new TRAID partition ahead of time to get the extra 8TB capacity.
jehuty
Spain
Post by jehuty »
I don't want a new partition. I want to replace the drives one by one and rebuild the TRAID. I prefer not to lose any data or permission adjustments.
You can follow these steps to replace each hard drive individually.
1. Press the power button briefly to turn off the TNAS. Wait until the power indicator light goes out, remove the disk you want to replace, and insert a larger capacity disk.
2. Press the power button briefly to turn on the TNAS. You will hear continuous beeping sounds, and the message center will report that the array has been downgraded. Go to the right side of the TOS desktop to turn off the beeper.
3. Go to TOS Control Panel > Storage Management > Storage Pool (which will display as degraded array) > Edit > Select Expand Array > Choose the newly added disk > Confirm settings.
4. If you need to replace multiple disks, wait for the array synchronization to complete, then repeat steps 1, 2, and 3.
5. Go to TOS Control Panel > Storage Management > Volumes > Edit, and adjust the volume capacity according to your needs.
jehuty
Spain
Post by jehuty »
Everything went great following your instructions. Thank you very much!
aaronsdropzone
Post by aaronsdropzone »
Does this work differently for TRAID configuration? I'm trying to add a 6GB drive to my two 8GB drives that are currently in TRAID but none of the options are available to me and I'm stuck.
