TOS 7.0.0777 Official Release (X86) is Now Available
Re: TOS 7.0.0777 Official Release (X86) is Now Available
My updated to 7.0.0777—no problems.
F8 SSD Plus MADN0301. V02 TOS 7.0.1188
Hypercache sorted with crisisacting's post, many thanks. Openclaw can only be installed manually.
F2-423
TOS 7.0.1105 (X86) (Still in Beta as there are way to many problems)
- sianderson
- Silver Member
this maybe related to TOS 7 in general rather than the 0777 release, but i noticed that my Jellyfin no longer had access to my libraries, even though i told TOS to auto convert the permissions
while it seemed that the higher level folder had Jellyfin permissions, the subfolders / files did not, i had to go in and use the advanced options to get the permissions to inherit, all working again once i had realised it was permission issues but thought i would just mention it incase other people have the same issue
F2-424 TOS 7.0.1169
F2-423 TOS 7.0.1169
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
F2-423 TOS 7.0.1169
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
Think so same me plex little issue this not won't auto scanning ... some issue TOSsianderson wrote: ↑12 Jul 2026, 20:44 this maybe related to TOS 7 in general rather than the 0777 release, but i noticed that my Jellyfin no longer had access to my libraries, even though i told TOS to auto convert the permissions
- sianderson
- Silver Member
yeah i noticed plex permissions as well so probably the same issuedrduszek wrote: ↑12 Jul 2026, 23:55Think so same me plex little issue this not won't auto scanning ... some issue TOSsianderson wrote: ↑12 Jul 2026, 20:44 this maybe related to TOS 7 in general rather than the 0777 release, but i noticed that my Jellyfin no longer had access to my libraries, even though i told TOS to auto convert the permissions
if you need help, go to Control Panel, Shared Folders, Edit the shared folder, Permissions Tab, Select Application Users
click the check box to Customize for the Plex User
tick the check box "Apply to this folder, subfolders and files"
Click apply
this should then spend some time (Depending how many files you have) setting the correct permissions
F2-424 TOS 7.0.1169
F2-423 TOS 7.0.1169
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
F2-423 TOS 7.0.1169
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
yes that made but maybe bug app plex will next version
Thank you for sharing your experience and detailed information.sianderson wrote: ↑12 Jul 2026, 20:44 this maybe related to TOS 7 in general rather than the 0777 release, but i noticed that my Jellyfin no longer had access to my libraries, even though i told TOS to auto convert the permissions
We have confirmed that this issue is related to the permission inheritance mechanism during the TOS 7 upgrade process. In some cases, the permissions of the parent folders were converted correctly, but the permissions of subfolders and files were not inherited as expected, which caused applications such as Jellyfin to lose access to media libraries.
This issue has been identified and fixed, and the improvement will be included in a future TOS version.
We appreciate your feedback and for sharing the workaround with the community. This information will help other users who may encounter similar permission-related issues.
I can confirm that this fix worked for me too and my HDDs are now sleeping peacefully.TMzethar wrote: ↑12 Jul 2026, 11:25We will conduct a verification of the matter you have brought to our attention.jayjay wrote: ↑11 Jul 2026, 18:59there are actually a lot of processes there, but I found that the drives go to sleep when I turn off smartI know it's not a great solution, but nothing else helpedCode: Select all
systemctl stop smartmontools.service
Additionally, in the smartmontools logs I noticed that the process queries the disks for temperature every 30 minutes, maybe this is the reason for waking up?
I reported this during beta but it was ignored. I had to recreate everything and then migrate all the files.sianderson wrote: ↑12 Jul 2026, 20:44 this maybe related to TOS 7 in general rather than the 0777 release, but i noticed that my Jellyfin no longer had access to my libraries, even though i told TOS to auto convert the permissions
Is there any plans to update portainer? My portainer shows 2.24 which was released November 2024.
