TOS 4.1.30 is released for update
scoobyfizz
Re: TOS 4.1.30 is released for update
Post by scoobyfizz »
Just a reply on the memory issue on the f2-210.. I thought it was solved but it appears that after 3 days my memory (with no additional apps loaded) has crept from about 20% to over 60%.. A reboot put it back down again.. The only thing I have this server for is as a backup so I have a regular Rsyinc on my QNAP to my terramaster..
So this update is good, but not quite fixed.... The culprit seems to be the msgcenter process.
Best thing I ever did was ebay my Terramaster...
yorch
Post by yorch »
this version, 4.1.30, keeps crashing when you share a file or folder.
When you create a link to send someone, to share a file, if you put a password, it does not let you enter to see what is shared. On the other hand, if you create the link and do not enter a password, what is shared is displayed correctly.
I already detected this bug in version 4.1.27 and version 30, it is still not solved ... INADMISSIBLE.
F2-221
yorch
Post by yorch »
yorch wrote: ↑19 Aug 2020, 19:53 this version, 4.1.30, keeps crashing when you share a file or folder.
When will this bug be fixed? It is a function that I use a lot, and it is the main reason why I have not yet updated to that version.
F2-221
Tricky
Post by Tricky »
Just noticed an update for the media server and when it completed it was disabled and had reverted to the photo, movie and music presets.
yorch
Post by yorch »
Tricky wrote: ↑21 Aug 2020, 00:36 Just noticed an update for the media server and when it completed it was disabled and had reverted to the photo, movie and music presets.
Yes, i know. tanks
F2-221
yorch
Post by yorch »
why can't i edit the storage quota users?
I am with brtf system. now I have realized, when registering a user, that I have no storage quotas, I cannot edit or create storage quotas.
F2-221
Tricky
Post by Tricky »
yorch wrote: ↑21 Aug 2020, 01:17
Yes, i know. tanks
It was a report/feedback to the admin/support.
Arjan21
Post by Arjan21 »
The function auto empty recycle bin after ---- days is still not working.
Also empty recycle bin (in the SMB tab) won't work. When I use SMB I've to remove them manually.
The hidden folders for a user are still not hidden with SMB, only with AFP.
But the new software looks like to run really stable for me (F2-210). The GUI runs faster than the last version.
Tricky
Post by Tricky »
Another bug report...had a power outage last night and the TNAS didn't re-power after despite the auto turn on after power out being turned on and still on after restart.
yorch
Post by yorch »
Tricky wrote: ↑21 Aug 2020, 16:21 Another bug report...had a power outage last night and the TNAS didn't re-power after despite the auto turn on after power out being turned on and still on after restart.
Hello good, I understood that this option of auto turn On, was when the Tnas is connected to an ups and by the usb also to the ups as well. If you have a sudden outage, you don't save the orders to rearm the Tnas.
F2-221
