Do you mean you can't start "debug" mode? Could you please describe it in detail?
TOS 6.0.555 (X86) is Released for Update
Re: TOS 6.0.555 (X86) is Released for Update
I can confirm that the automatic nas shutdown does not work.
- ChairmanMao
Oops, my bad. I can see your's running perfectly fine.Gremlin wrote: ↑19 Dec 2024, 20:37Maybe you could identify your system (model/Tos version) so someone can make sense of what you are stating.Code: Select all
{senselessusername}@NAS-T1:/# cat /sys/kernel/debug/dri/0/gt/uc/guc_info GuC firmware: i915/tgl_guc_70.bin status: RUNNING
I've updated my firmware to this latest version and on inputting those command. I received an output of "GuC disabled".
F4-423, TOS 6.0.555
My F5-422 updated without problems 5.1.145 - 6.0.530 - 6.0555. After correcting the rights to the folders, Plex started working. But qbittorrent does not want to start. When I try to start it says "operation failed". Please tell me what other settings I should look at?
F5-422 TOS6 5x2.00TB HDD WD IronWolf
Sorry, Works fine. Mine shuts down every night and re-starts every morning, as I set it to do.
The problem was solved by installing new version of qbittorrent 4.6.6 from outkastm together with required phyton 3.8
We factory reset the nases that was affected by the kernel panic and smb unstable.
Once factory reset everything was ok.
So proboly something in the update must gone wrong or corrupted. but once factory reset was done everything was stable.
