TOS 5.1.79 (X86) is Released for Update
MapaM
Spain
Re: TOS 5.1.79 (X86) is Released for Update
Post by MapaM »
In App Center > Settings:
Hard drives are not identified
F6-424 + D4-300
{L_BUTTON_AT}MapaM
We have not reproduced or received similar feedback. Your issue may have been caused by other reasons, rather than TOS 5.1.79 Please open a separate topic post, or contact the customer service window or technical support email to investigate the issue. The abnormality you encountered may be related to this: viewtopic.php?f=28&t=4912
brunix86
Italy
Post by brunix86 »
{L_BUTTON_AT}TMLyy
Hi, any news about the patch\release to fix the date\time format issue in 5.1.79 version?
Thanks and Best Regards
My NAS Environment
  • TNAS F4-424
  • TOS 7.0.1536 (8GB System Partition)
  • 1x RAM Terramaster 8GB DDR5 4800 MHZ
  • 2x HDD Seagate IronWolf 12TB CMR [RAID1]
{L_BUTTON_AT}brunix86
The issue has been fixed, please wait for the next TOS5 release version.
MapaM
Spain
Post by MapaM »
{L_BUTTON_AT}MapaM
TMzethar wrote: ↑02 Nov 2023, 18:24 We have not reproduced or received similar feedback. Your issue may have been caused by other reasons, rather than TOS 5.1.79 Please open a separate topic post, or contact the customer service window or technical support email to investigate the issue. The abnormality you encountered may be related to this: viewtopic.php?f=28&t=4912
This issue has been fixed. One of the things I noticed was that the volumes did not appear in the status side widget and if I went to "control panel > volume" the wizard for creating a new volume / storage group appeared. Before doing anything, restart the NAS and the problem is fixed. Thanks for your time
F6-424 + D4-300
DaSatelliteguy
Post by DaSatelliteguy »
Updated from 5.1.67 to 5.1.79 with no issues whatsoever. Time and date format works perfectly. Thanks!
BorizzK
Post by BorizzK »
I found problems with the samba service
Permissions to shared folders are not remembered
In On-Line users i see user daemon
i try to reset TNAS to default
{L_BUTTON_AT}BorizzK
Your question may not be related to this update. Guess you may have modified the permissions, which will take some time to gradually modify all directories and files. The process you saw before may be related to modifying permissions.
ostaporomo
Finland
Post by ostaporomo »
ostaporomo wrote: ↑25 Oct 2023, 02:10 Another bug of the new firmware.
When using the scheduled on/off function, when the system is turned on, the disks installed in the D 4-300 do not start up randomly (the D 4-300 is connected to the F2-223, two disks in ride 1, one for torrents and one for file storage).
I rechecked the status of the disks using the Victoria program. No errors found.
There were no such problems on TOS 5.1.67 firmware.
Dear developers, please tell me how to return to TOS 5.1.67 firmware from TOS 5.1.79?
I was able to determine the cause of the problem.
As it turns out, the qBittorrent application downloaded from the Application Center is not compatible with TOS 5.1.79. When the system is turned off, qBittorrent does not seem to stop read/write operations on disks, which leads to unpleasant consequences.
By switching to transmission, I completely got rid of the problems with disks falling off.
There was no such problem on the TOS 5.1.67 system.
TNAS F2-223
TOS 5.1.79-00214
2x RAM Samsung 16GB DDR4 2133 MHZ
2x HDD Segate IronWolf ST4000VN008 4TB [RAID1]
DAS D4-300
2x HDD Seagate SkyHawk ST3000VX010  [RAID1]
2x HDD Toshiba DT01 DT01ACA300-3TB
Do you mean after TNAS shuts down? Some hard drives have a delayed stop feature, which keeps them spinning even after the system is turned off in order to ensure that all data has been correctly written to the disk. How did you determine this? Have you tried shutting down the system without using this software?
