TOS 5.1.40 (X86) is Released for Update
ckl
Re: TOS 5.1.40 (X86) is Released for update
Post by ckl »
Hi.
It's been a while since I created my shared folders and I'm not sure if they are encrypted or not. As a test, I created a test encrypted shared folder and then viewed the shared folder list but it doesn't specify whether it is encrypted. It just looks like any other folder...
Is there a way I can tell which folders are encrypted?
Thanks.
crisisacting
Post by crisisacting »
ckl wrote: 12 Jul 2023, 13:07 Is there a way I can tell which folders are encrypted?
One way to figure this out would be that Encrypted Folders require key entry after a restart of TOS.
Beyond the additional menu in TOS itself, there isn't currently a visual representation to quickly identify them.
crisisacting wrote: 12 Jul 2023, 15:46 there isn't currently a visual representation to quickly identify them.
Nor would you necessarily want it. Encrypted folder says "Here is something I want kept private". Identifying such to the casual scanner says "Here is something worth an attempted hack". :twisted:
crisisacting
Gremlin wrote: 12 Jul 2023, 15:51
On the TOS interface itself, a differentiating icon/marker/description would be helpful.
From the protocol aspect, definitely show all folders similarly; unless it's set to public without credentials, every share should already require username+password.
migas
Post by migas »
After upgrading my TNAS F2-221 from version 5.1.24 to version 5.1.40, on reboot i have 3 beeps and after whe acessing using the browser it gives a "No hard drive detected" message and goes to "Initialization" page.
No ssh or smb access working.
What can I do?
migas wrote: 16 Jul 2023, 07:18 After upgrading my TNAS F2-221 from version 5.1.24 to version 5.1.40, on reboot i have 3 beeps and after whe acessing using the browser it gives a "No hard drive detected" message and goes to "Initialization" page.
What can I do?
Have you ever used TOS4? The system partition may be small and there may be an upgrade issue. (Please refer to the red note on the first page) Please try installing TOS 5.124 back.
davidecavestro
Italy
Post by davidecavestro »
Just to give feedback: I've just bought a new F2-223, booted and let it init with default config (scratch install I suppose).
At first restart the bootloader complained for missing file, i.e. setup.symbol `grub_fshelp_find_file_lookup` not found
To make it boot again I had to enter BIOS bootloader section and change disks order, moving the internal storage before HDD.
TOS version: 5.1.40
BIOS/initBoot version: 5.19
tommi2day
Germany
Post by tommi2day »
Yep, the same i had with the previous version: viewtopic.php?f=28&t=4733&p=27361#p27361
Unfortunatly, my T9-450 dont have an HDMI port to see the error, i had to find out how to use the console port
Thomas
main: T9-450
akaserge
Post by akaserge »
Updated from 5.1.33 without any issues.
Model F2-221 TOS Version 6.0.794
davidecavestro
Italy
tommi2day wrote: 18 Jul 2023, 01:05 Yep, the same i had with the previous version: viewtopic.php?f=28&t=4733&p=27361#p27361
Thomas
Actually your comment saved my day, that's why I have feedback
