TOS 5.0.176 (x.86) is Released for Update
gaz2k1uk
Re: TOS 5.0.176 (x.86) is Released for Update
Post by gaz2k1uk »
I still cannot access via SMB unless I change my password, can you please assist? Thanks
Gandalf1369
Post by Gandalf1369 »
When I install Portainer on my F4-220 under TOS 5.0.176 it installed version 2.1.1. When I look at the info in the App Center for Portainer it indicates that the version available is 2.13.1. Could you please fix it so that the correct version (2.13.1) is downloaded and installed thru the App Center . . .
Thank you
Soylent_Geek
Post by Soylent_Geek »
Hi
Will there be a release of 5.0 that fixes the "System is Sluggish" notifications?
I have an F4-220 so I can't go to 5.1.
I'd hope we will still get 5.0 updates till 5.1 comes out of beta and becomes available for the model I have.
D
emperorgr
Greece
Post by emperorgr »
Getting that certificate that expired, TNAS Online is enabled and registered at EU server. At the certificate page the *.cn.tnas.link is updated to 11/10/2023, while a second certificate terra-master.com shows that has expired 74 days, how can i fix this?
