The Brand New TOS 5 is Released!
shyte97
Re: The Brand New TOS 5 Officially Released Today!
Post by shyte97 »
Authenticate wrote:
> Plex app and docker app seem to not be working in this update? Plex app
> loads but cant see my mounted data. Docker just keeps saving configuration
> but nothening happens.
I had the same issue with Plex not seeing the folder I had all my media in. Went to file manager, right clicked on the folder and then the drop down for 'user group'. Changed media to read/write. After that change I was able to add a media library into plex server.
shyte97
Post by shyte97 »
Veggieboy wrote:
> Security Isolation mode disconnects the internet, hence no apps. You need
> to leave isolation mode long enough to install apps.
That was it. Thanks.
Authenticate
Post by Authenticate »
shyte97 wrote:
Thanks worked!
{L_BUTTON_AT}JoKr
If you encounter a prompt to format your hard drive, you can contact our tech team for assistance.
Izo
Bulgaria
Post by Izo »
My device is F4-220 and i have 3 HDDs on 3 data pools and 3 volumes. After TOS 5 installation, HDD1 on data pool 1 was set to be Volume 1, HDD2 on data pool 2 was set to be Volume 2, HDD3 on data pool 3 was set to be Volume 3. After restart i saw that the HDD 1 became Volume 3 and HDD 3 became Volume 1. What do i do wrong?
Please help!
OllieHardy
Post by OllieHardy »
I still haven't been able to install the TNAS PC update on my windows computer, the exact same problem as yourself. Have you had any luck? I tried everything they suggested
Charlie_Croker
Saudi Arabia
Post by Charlie_Croker »
@janb wrote:
V5.0.12 doesnt work on Monterey, (didn’t for me during beta), try the latest v 5.22 https://download2.terra-master.com/Terr ... 5.0.22.dmg
I can’t vouch for it, I’m on Ventura Dev Beta 1
Roccia7
Italy
Post by Roccia7 »
Roccia7 wrote:
> I followed instruction to update tos, and now nas doesn't start. When i
> reset to factory default tnas restart and never boot up. I waited for about
> 30 minutes and nothing append. I tried to restart without hd inserted and
> tnas wont boot up.
> I have f2-220. Now what can i do?
Could someone from support help me?
Which version of TOS running on your F2-220 before you reset it to factory default?
{L_BUTTON_AT}OllieHardy
We will release a new version to fix the issue soon.
