[ jDownloader ] download management tool
Re: [ jDownloader ][2.00.03] download management tool
added back
MisterXY
Germany
Post by MisterXY »
thx for your work.
Anything must be wrong with the logfile
MisterXY
Germany
Post by MisterXY »
Forget my post, it was my fault. Had changed the log file size myself and therefore no log file was created.
So things are going well.
dataonly
Australia
Post by dataonly »
Hi, i have installed the app, downloaded a few file but couldn't find the downloaded file anywhere,
I have tried setting the folder destination to : /mnt/Terramaster-share/Download (Terramaster-share is the folder i created as sharefolder to store all the download and for other user to access them)
eulero
Italy
Post by eulero »
Ciao Outk,
last version of TOS5 x64 - the sofftware has been installed but doesn't start, neither if i try to activate manually ... usual problem.
Can you fix it please?
Eulero
Current System:
F2-422 - 4TB storage
TOS- 7.0.0333
Re: [ jDownloader ] download management tool
try the latest version for TOS5
doctorase
Post by doctorase »
I've installed oracle dependency and edited de config file with my account password and mail, but it shows this error.
I've read all the forum and seems that is error appears with other users that doens't have installed oracle, but it's not my case. I've searched the file and folder showed in the message and it exist.
SoLX
Post by SoLX »
Hi there,
Having issues, I was able to successfully install the latest version, 2.00.04, along with the required prerequisites (OracleJRE8). I created an account through Jdownloader as instructed but inputting the login information didn't work. So I decided to perhaps reinstall Jdownloader. So I uninstalled but I can no longer install it again. It gets stuck on the installation screen on TOS and stays at 0%. I couldn't find the folder where Jdownloader was installed in my NAS, I'm thinking that there maybe leftover files causing this.
Any advice would be great
peskat
Greece
Post by peskat »
SoLX wrote: ↑17 Mar 2024, 00:01 Hi there,
I have the same issue. I managed to find all the jDownloader folders and files left behind through ssh, but even after removing them, installation gets stuck at 0%.
I have even deleted and redownloaded the tpk with no change.
F4-424 Pro 3x12TB IronWolf / 1TB Samsung 980
D8 Hybrid
MisterXY
Germany
Post by MisterXY »
Will there also be a version for TOS6?
Greetings
