[ModBase1] Common libraries and tools for use by other modules
XFNeo
Re: [ModBase1] Common libraries and tools for use by other modules
Post by XFNeo »
{L_BUTTON_AT}outkastm
Hi! Could you please add iotop and htop. Thanks!
XFNeo
Post by XFNeo »
outkastm wrote: ↑26 Apr 2023, 06:10 htop available
https://tmnascommunity.eu/download/htop/
It does not work properly F1 to F10 does not work in htop
Do you have colors?
XFNeo
Post by XFNeo »
After reboot it works properly. Thx
XFNeo
Post by XFNeo »
outkastm wrote: ↑26 Apr 2023, 18:38 Do you have colors?
At first time no)
Because the terminal have to change to xterm to get the colors and special keys functions.
seb59494
Post by seb59494 »
Hi
I'm using version ModBase 1.00.16. On a F2-221 with TOS 5.1.24, when I click on "add to path", the application is not added to the Path : the UI panel shows "ModBase1 is not available in PATH " and ModBase1 is not found by both ffmpeg51 and jellyfin (indicating that the modbase1 has not been added to the path".
=> what can I do to add it manually ?
seb59494
Post by seb59494 »
Hi
Appologize for my previous message, here is a new one with more info:
I ssh into the system and checked the folders. /usr/local/ModBase1/sys/ exists but there is no "bin" folder inside, just a "lib/dri/..." subfolders.
Also, the web ui is not accessible (even after starting the module into the GUI). I also rebooted the NAS, but it did not changed anything.
So can you tell me where the binaries are located in my installation and how to add them manually to the path, knowing that I'm a noob linux user that only knows how to navigate into the folders :oops: :cry:
Thanks for your help
Spider
Post by Spider »
I am on F4-220 running TOS Ver 5.1.40. I have ModBase1, ffmpeg, ffmpeg51 and Jellyfin install. ffmpeg, ffmpeg51 and Jellyfin are all saying ModBase1 app is not installed. I tried going http(s)://yournasip:port/modules/ModBase1/www, but get 404 not found.
Any help would be great
