How to fix a faulty USB initBoot for your TNAS?(220/420/221/421/422)
ianaway
Re: How to burn a new USB initBoot for your TNAS?(x86)
Post by ianaway »
Scorp wrote: ↑29 Jul 2022, 01:59 And I've managed to make it eventually. Used installation package and bootloader v5.1.96. It's packed with 7z btw. =) But problem was not in USB. Problem was with nvme disks, where TOS was installed. I used ubuntu live CD to destroy partitions on NVME and only after this NAS loaded.
I will try to wipe my nvme … maybe my issue is there ! It crashed during the TOS 5 install on the first boot
Thanks ! ;)
Spider
Post by Spider »
I have the F4220. Getting the following messages "Failed to load the Bootloader!
Failed to load the Bootloader from server! Please check if your device is successfully connected to the internet. You can also manually download it from our server and upload it in the column below." I SSH into the system and executed the following command "/etc/init.d/mountusb start" I got no USB found.
Help!!!
{L_BUTTON_AT}Spider
You can download the bootloader in our website.
Spider
Post by Spider »
Thank you just did that and will let you know once installed if it worked or not.
stivm
Post by stivm »
this method is not suitable for f4-423 it only has uefi boot. How can I recover usb for f4-423?
{L_BUTTON_AT}stivm
Please wait for the new guidelines.
stivm
Post by stivm »
tell me how to restore bootable usb, I also have f4-423, it only supports uefi
Scorp
Post by Scorp »
stivm wrote: ↑03 Sep 2022, 04:31 tell me how to restore bootable usb, I also have f4-423, it only supports uefi
My NAS still syncing raid, so I can't turn it off. However, i can make bin image of USB and post it if there is no private data on it and developers don't mind that.
Spider
Re: How to fix a faulty USB initBoot for your TNAS?(x86)
Post by Spider »
I was able to get this working again by removing the USB stick and re-inserting it.
{L_BUTTON_AT}Spider
May I know what is your model number? and how long has your device been used?
