TOS 5.1.79 (X86) is Released for Update
yak983
Re: TOS 5.1.79 (X86) is Released for Update
Post by yak983 »
{L_BUTTON_AT}yak983
TMzethar wrote: ↑25 Oct 2023, 18:23 If you are unable to backup them, it is recommended to keep using TOS 5.124 and earlier versions. You can obtain the installation package from the download center.
how? i can access only to ssh
yak983 wrote: ↑25 Oct 2023, 16:18
i have 58TB of data so i can't delete the partition to make 8gb partition
58TB of data on a NAS, without a backup. Seriously? You must have a great deal of faith...........
Frustrated Beta Tester!!!
yak983
Post by yak983 »
i have fix the problem using a old version, now how i can resize the OS partition from 2GB to 8GB?
/dev/md9 1.9G 1.6G 233M 87% /
cat /proc/partitions
major minor #blocks name
8 0 15625879552 sda
8 1 291840 sda1
8 2 1999872 sda2
8 3 1000448 sda3
8 4 15622585344 sda4
8 16 15625879552 sdb
8 17 291840 sdb1
8 18 1999872 sdb2
8 19 1000448 sdb3
8 20 15622585344 sdb4
8 32 15625879552 sdc
8 33 291840 sdc1
8 34 1999872 sdc2
8 35 1000448 sdc3
8 36 15622585344 sdc4
8 48 15625879552 sdd
8 49 291840 sdd1
8 50 1999872 sdd2
8 51 1000448 sdd3
8 52 15622585344 sdd4
8 64 15625879552 sde
8 65 291840 sde1
8 66 1999872 sde2
8 67 1000448 sde3
8 68 15622585344 sde4
9 9 1998848 md9
9 8 999872 md8
9 0 62489817088 md0
252 0 62489812992 dm-0
bretwashere
Post by bretwashere »
Installed 5.1.79 last weekend, and all went good and the installing is unremarkable.
Alessio71
Italy
Post by Alessio71 »
ostaporomo wrote: ↑23 Oct 2023, 16:15 [at=Alessio71 post_id=30541 time=1698001813 user_id=5675][/at]
After changing the date display format, my NAS turns off and turns on according to the script without any failures or problems.
Try it, you will succeed.
If developers cannot release software without such annoying errors, we ourselves must help each other and restore the operation of our NAS :)
Mine still doesn't :(
Don't post any thread not related to the topic. To report other issues not related to system updates, please create a new topic in corresponding forum.
ostaporomo
Finland
Post by ostaporomo »
Dear developers, answer this question.
Is it possible to return to the previous firmware without wiping the system and data? As it turned out, the new firmware does not work well with DAS.
TNAS F2-223
TOS 5.1.79-00214
2x RAM Samsung 16GB DDR4 2133 MHZ
2x HDD Segate IronWolf ST4000VN008 4TB [RAID1]
DAS D4-300
2x HDD Seagate SkyHawk ST3000VX010  [RAID1]
2x HDD Toshiba DT01 DT01ACA300-3TB
BorizzK
Post by BorizzK »
TMroy wrote: ↑31 Oct 2023, 11:07 Don't post any thread not related to the topic. To report other issues not related to system updates, please create a new topic in corresponding forum.
My TOS lost cache AFTER update to this release
emperorgr
Greece
Post by emperorgr »
how is the SMB read/write speeds with Windows operating systems? I had terrible performance with 5.1.67, while 5.1.49 is perfect..
