TOS 5.1.41 (X86) is Released for Update
Re: TOS 5.1.41 (X86) is Released for Update
Something stops your SMB service from normally starting during the system reboot, this moment I do not know what it could be. BUT it is going too far under this topic, please create a new thread for any issue not related to the current TOS update. Thanks!
joka388
Austria
Post by joka388 »
Gremlin wrote: ↑18 Aug 2023, 17:27 I can confirm SMB was disabled after restart following above shutdown/restart
Also here
F2-221 6 Gb RAM - 2x8TB
F4-425 16 Gb RAM - 4x4TB
{L_BUTTON_AT}TMroy
Merely confirming 2 previous reports of SMB disabled after restart (and now a fourth!). I suspect it IS related to this update 5.1.41. The "something" appears to be your OS.
DERIKKU
Post by DERIKKU »
Gremlin wrote: ↑19 Aug 2023, 14:48 [at=TMroy post_id=29139 time=1692422519 user_id=1656][/at]
Yes it is. with other firmware i don't have this problem. only with this version :roll:
F5-221
TNAS 10TB
RAM 10GB
What features do you use? Domain, Scheduled Tasks, or anything else?
In my case I use a fairly basic setup. Repository for (SMB) backups (which obviously fail after shutdown/restart - hence my comment - and was not an issue prior to 5.1.41), FTP picture storage from multiple CCTV cameras and simple scheduled tasks to clean (using 'find') picture storage. Snapshot is installed, but only 'file system snapshot' is used. USB copy installed, but not active.
Hth.
ps I would like to clarify. This (SMB disabled) only happens after a POWER OFF shutdown. It does not happen after a simple 'restart'. Trust that makes things clearer.
TMlinda
Post by TMlinda »
{L_BUTTON_AT}Gremlin
This problem has not been reproduced in our laboratory, please contact our technical team to conduct a remote inspection for you, you can find the contact information in my signature.
crisisacting
Post by crisisacting »
{L_BUTTON_AT}TMwuu
Just did a clean install of 5.1.41 into a F5-220 and it also reports:
BOOT_IMAGE=/boot/bzImage type=raid
when running
cat /proc/cmdline
through SSH. Also, the bootloader is only version 1.0.2 on the unit; is that the newest one for it?
TMlinda
Post by TMlinda »
{L_BUTTON_AT}crisisacting
This is normal, and the latest version 5.1.44 online will be automatically loaded after 30 seconds.
