TNAS mobile 3 Beta is released for testing NOW!
dataonly
Australia
Re: TNAS mobile 3 Beta is released for testing NOW!
Post by dataonly »
Updated to the latest version 2 days ago all of sudden it keep crashing so I deleted the app and installed it again now I cant login again, keep getting connection lost, please login again.
{L_BUTTON_AT}dataonly
Is it normal to access TOS via the web? Is the mobile phone used within or outside the LAN? Is "Force Redirect to HTTPS" enabled in Control Panel - Network?
dataonly
Australia
Post by dataonly »
Access is normal via web
iPhone used within LAN
Force redirected to https is not enabled.
It was fine 2 days ago (so setting on the server itself must be correct as it is unchanged) after I updated the app and was in the process of backing up my files/photos all of sudden it keep crashing hence I deleted and reinstalled the app and now I get the error and cant login using the Tnas mobile app.
I can access tnas using the tnas mobile 3 app installed on my dad’s android just the app on my iPhone is failing.
dataonly
Australia
Post by dataonly »
Also when I open the tnas mobile app on my iPhone Tnas was not detected automatically even though phone was on LAN
Try to add my tnas details manually and get the error
TWlhq
Post by TWlhq »
Is the cpu usage rate too high?
Try to reinstall TNAS Mobile 3 again. Its latest version is 3.0.13.
dataonly
Australia
Post by dataonly »
Same prob after reinstalling the app
Please check that the network access permission of app is enabled. If it is enabled, you can try turning WiFi off and on again.
alexmv
Post by alexmv »
Both it didn't work on iOS and doesn't work on the local network.
F4-423
TOS 6.9.229-001
32 RAM
TRAID
{L_BUTTON_AT}alexmv
What is your model number? and what is the TOS version?
leandrosakae
Post by leandrosakae »
{L_BUTTON_AT}TMroy
I have the same problem.
TOS 5.0.176
TNAS mobile 3
