TOS 5 Beta is released for testing NOW!
- Charlie_Croker
Re: TOS 5 Beta is released for testing NOW!
And had to reinstall TOS5 today:
1.File services were working OK
2. Plex was working OK
3. Unable to log in to the NAS. (tried with two PCs and an iPad), it was showing on my network but nothing.
4, After reinstall all apps and data was there, but Plex wouldn't "Enable" uninstalled Plex and then discovered its no longer showing as an App?
Bug report sent
Bug report sent
- Charlie_Croker
Plex has reappeared, reinstalled and all is good. No further issues
Out of curiosity, are you using the Plex TPK provided through TNAS or the one directly from Plex?
- Charlie_Croker
> directly from Plex?
The TM one, the Plex one will not install (I'm guessing its for TOS4)
> directly from Plex?
Good to know, that's unfortunate as the Plex version was way more updated than the TNAS one
Is there a way to downgrade back to stable? I am having to many problems with the beta, wonder if it is safe to factory reset, andd than install the latest stable build.
some of the problems I am experiencing
-tnas pc not visible on mac monterey
-not possible to create a storage pool with btrfs file system
-usbcopy not loading
-no progress/ status bar on background process + not possible to get the background process window back once it gets closed
actually, after reinstalling, usbcopy appears now to be running :)
- dissidence
after the last update, I am having some interesting issues, if I check for an update for the os it shows undefined, and no apps are available in the app store.
{L_BUTTON_AT}dissidence
Your device may not be connected to the internet, please follow the steps to solve the issue.
1. Enter the Control Panel-Network Settings-Network Interface, edit the used network port, and modify the DNS to 8.8.8.8
2. Confirm whether the gateway is consistent with the computer, if it is different, you need to change it to be consistent with the computer
3. Check the "Set as Default Gateway" button, and then click "Apply".
I Waited for a very Long time for this.
