TOS 4.2.16 is released for update!
Re: TOS 4.2.16 is released for update!
{L_BUTTON_AT}myrix
Please execute the following commands separately:
sudo cp /etc.default/profile /etc/
sudo source /etc/profile
sudo /etc/init.d/php-fpm restart
myrix
Post by myrix »
@TMSupport
It Works :D
Thanks o/
Regards
Makineta
Post by Makineta »
I have a F2-422 NAS. With this version disks not entry in standby. I configured 30 minutes, I had waiting for 3 days. What can I do for fix It?
Thanks in advanced,
{L_BUTTON_AT}Makineta
Hi! "disk in standby"? Do you mean hard drive hibernation? If yes, please refer to the article for troubleshooting:viewtopic.php?f=75&t=473
SunDogBC
Post by SunDogBC »
I'm curious why I have to manually download updates when there is an option for "Online update (recommended)"? Is this an "early adopter"-type release or something not set to update in this manner?
My current version is 4.2.15-2107221409.
F2-221 - TOS7.0.0403
BIOS/InitBoot version- MAPL0304V17
TNAS mobile (Android) - V3.5.044
{L_BUTTON_AT}SunDogBC
Hi! Currently TOS4.2.16 can only be updated manually. The online update has not yet been pushed 4.2.16.
tutuzik
Post by tutuzik »
the web server does not turn on, how to solve the problem ??
{L_BUTTON_AT}tutuzik
Hi! The issue has been fixed, please go to the application center to update Web Server.
LSDWho
Post by LSDWho »
Have upgraded my F5-221 to 4.2.16 but it has caused me a few issues:
SMB was disabled - no biggie initially as easily re-enabled it.
Plex is killed - service just enters a "stop" state as soon as you try to start it. This has happened a few times in the past and I've had to wipe the data folder (/home/plex/Library/Application Support/Plex Media Server) and start from scratch. It's a pain in the bum but it works. However, I can't do this now due to my third issue....
I can't SSH to the box. Firstly, like SMB, the update turned this off. I've re-enabled it but now every time I try to connect I can't log in as root (ssh [email protected] -p 9222). I'm prompted for the password, which as always I put in the same password as the admin account. But it won't accept it and just repeatedly prompts for the password.
Any ideas on what may be causing this any any possible fixes?
Cheers
Hardfecx
Post by Hardfecx »
I don't know much about ssh but is there no possibility to enter a command like "Forget password" and get an e-mail to reset it?
While i am typing it I don't think so....
Has you the possibiliy to review the permissions of root - users..?
