[ jDownloader ] download management tool
Re: [ jDownloader ][2.00.03] download management tool
Have you tried to restart the app ? Check also the log files.
I don't have any connection issue here
MisterXY
Germany
Post by MisterXY »
Any News about for Jdownloader for TOS5?
And a news for a new JRE Version for Jdownloader?
Added on the to do list
MisterXY
Germany
Post by MisterXY »
Nice to hear that
Added TOS5 version.
The recommended version for Java is 1.8.0, so this was also updated to 1.8.0_321
MisterXY
Germany
Post by MisterXY »
In Application Control I miss things like Start Jdownloader, Stop Jdownloader, enable Autostart, disable autostart etc.
I just restart Jdownloader and remove config there.
I removed them from the menu.
in TOS 5 you can Start/Stop from the App Center
MisterXY
Germany
Post by MisterXY »
OK, by enabling/disabling I also automatically set the enable_autostart and disable_autostart function.
The old menu was a bit better (in my opinion).
MisterXY wrote: ↑20 Jul 2022, 13:42 OK, by enabling/disabling I also automatically set the enable_autostart and disable_autostart function.
indeed, by enabling/disabling from the App Center you also automatically set the enable_autostart and disable_autostart function.
This was implemented by TM in the App Center.
If you find useful to have them also on my frontend UI, i will consider to add them back
MisterXY
Germany
Post by MisterXY »
But that's just my opinion. I thought it was solved really nicely before. I could decide if I want to start or stop or restart it and if I want to have it started via autostart or not.
Now it's a bit more complicated.
