[ apache24 (PHP 7) ] Web Server
jfxcube
Re: [ apache24 (PHP 7) ] Web Server
Post by jfxcube »
outkastm wrote: ↑11 Dec 2022, 07:57 download again the app and install it, for TOS5 used apache24 TOS5 2.4.54.1 x86_64.tpk
hello
i already used the right package apache24 TOS5 2.4.54.1 x86_64.tpk, sorry for the typo, but it shows the above problems
Thanks a lot
Have you downloaded again the file and install?
jfxcube
Post by jfxcube »
outkastm wrote: ↑11 Dec 2022, 21:03 Have you downloaded again the file and install?
Not yet cause it says i can t before 6 days
jfxcube
Post by jfxcube »
Hello outkastm
i downloaded and installed again but the problem remain the same.
i downloaded also the packet apache24_TOS5_2.4.54.0_x86_64.tpk and this is working properly.
Thank you very much
Try to remove completelly the existing version, including the config files
Download again the latest version for TOS5 and install it (i made small changes for log creation)
Does the installation create the icon on the desktop now ?
Try to click on Help & Support, is the WebUI opening now ?
If the message say apache is stopped, check the start log
sanctimon
Post by sanctimon »
Can this be used with your version of Php8.0?
And what sort of changes should be made in the other apps, like Nextcloud, Jellyfin and phpmyAdmin?
Yes it can be used, you have to edit php.ini and httpd.conf of each app as described in PHP8.0 app UI.
Jellyfin doesn't require php or apache
Daywalker
France
Post by Daywalker »
I have successfully installed apache24 TOS5 2.4.54.1 x86_64.tpk on my F5-422 TOS5 5.1.24 but apache24 can't start.
I haven't desktop icon
please help me
F5-422
Check the log file. If the app doesn't start, it won't create the desktop icon
Daywalker
France
Post by Daywalker »
{L_BUTTON_AT}outkastm
Ok thanks, I found my problem.
Now apache24 successfully started
F5-422
