How to fix a faulty USB initBoot for your TNAS?(220/420/221/421/422)
thefatbloke
Re: How to burn a new USB initBoot for your TNAS?(x86)
Post by thefatbloke »
Hi
I tried method 2, but every time I run './make_install bzImage' i get an error message about /media/ not being an efi partition, and the resulting usb drive doesnt work.
{L_BUTTON_AT}thefatbloke
Please send us a screenshot of the command you executed and the error message returned.
thefatbloke
The commands were copy and pasted from the instructions here.
Here is the terminal output:-
root@mint:/mnt# wget https://download2.terra-master.com/bzImage.zip
--2022-06-23 17:48:26-- https://download2.terra-master.com/bzImage.zip
Resolving download2.terra-master.com (download2.terra-master.com)... 8.208.41.140
Connecting to download2.terra-master.com (download2.terra-master.com)|8.208.41.140|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 37623188 (36M) [application/x-zip-compressed]
Saving to: ‘bzImage.zip’
bzImage.zip 100%[===============================================>] 35.88M 2.42MB/s in 14s
2022-06-23 17:48:41 (2.53 MB/s) - ‘bzImage.zip’ saved [37623188/37623188]
root@mint:/mnt# unzip bzImage.zip
Archive: bzImage.zip
inflating: Burn USB hard drive system Instruction.txt
inflating: bzImage
inflating: grub.cfg
inflating: make_install
root@mint:/mnt# chmod +x make_install
root@mint:/mnt# chmod +x grub.cfg
root@mint:/mnt# ./make_install
#########mkfs ext4#############
mke2fs 1.46.2 (28-Feb-2021)
/dev/sdb1 contains a vfat file system labelled 'USB STICK'
Proceed anyway? (y,N) y
Creating filesystem with 3907840 4k blocks and 977280 inodes
Filesystem UUID: c3c13f0a-f3c8-4e56-9d8c-de18eb4f9d85
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208
Allocating group tables: done
Writing inode tables: done
Creating journal (16384 blocks): done
Writing superblocks and filesystem accounting information: done
#########install grub###########
Installing for x86_64-efi platform.
grub-install: error: /media/ doesn't look like an EFI partition.
#########done##################
thefatbloke
It is an f2-221.
Is there a version of that page in english please?
Please check if the USB drive is healthy and try to clean the partition with your computer and try again. If the problem persists, you should be able to install TOS with it as well. If necessary, please contact the technical support mailbox.
inspecteur6
Post by inspecteur6 »
Hey Guys,
Been playing around making an usb stick for a F5 221.Tryed it on different hardware and it works. Openeing the GUI i get the message "piracy is illegal".
I can get in the Linux terminal and see all files etc etc. Any ideas what is causing this? Is this some hardware or something in the software.
Scorp
Post by Scorp »
Hello. I have F4-423. Used instructions from file to fix my USB initBoot, but it didn't work. The problem is - UEFI boot in this device. I've managed to boot bzImage with EFI grub bootloader, but it doesn't work properly. Then I tried to make usb boot from TerraMaster Bootloader V5.1.96 but Ubuntu can't read this img. Are there instructions to burn USB for EFI devices? Or maybe proper USB image? Thank you.
Scorp
Post by Scorp »
And I've managed to make it eventually. Used installation package and bootloader v5.1.96. It's packed with 7z btw. =) But problem was not in USB. Problem was with nvme disks, where TOS was installed. I used ubuntu live CD to destroy partitions on NVME and only after this NAS loaded.
ianaway
Post by ianaway »
Will that process work for a F4-423 ? Thanks !
This method is suitable for F4-423, but the online installation of this boot system will install TOS 4.2. When installing the system for the first time, you need to choose to manually install TOS 5.
