TOS 7.0.1130 (x86) Official Release Update
renob
Re: TOS 7.0.1130 (x86) Official Release Update
Post by renob »
TMroy wrote: ↑15 Aug 2026, 11:25 We'll be optimizing how NTP is configured. Please stay tuned for the upcoming update.
I assume /etc/ntp.conf should be displaying us.pool.ntp.org addresses?
# cat /etc/ntp.conf | head -n5
server 127.127.1.0 minpoll 6 maxpoll 10 iburst prefer
server 0.pool.ntp.org iburst
server 1.pool.ntp.org iburst
server 2.pool.ntp.org iburst
server 3.pool.ntp.org iburst
zeratyx
France
Post by zeratyx »
There is a French translation issue in the "Hardware and Power" menu; a word needs to be removed from the UPS section (see attachment).
EriChan
Post by EriChan »
renob wrote: ↑20 Aug 2026, 18:35
Your configuration has already taken effect. TOS stores the custom NTP server settings in the system configuration database rather than modifying /etc/ntp.conf.
/etc/ntp.conf is a factory default file containing fallback servers for the local ntpd service, and changing the time server in the TOS Control Panel will not overwrite it.
How to verify your NTP setting:
1. Check the active configured time server:
iniparse -c -f /etc/.default.sys -s system -k timeserver
2. Test manual sync:
ntpdate -u -b us.pool.ntp.org
3. Check the system time:
date
If the manual sync completes successfully and the system date is correct, NTP synchronization is working properly and you can safely disregard the contents of /etc/ntp.conf.
EriChan
Post by EriChan »
zeratyx wrote: ↑21 Aug 2026, 03:03
Thank you very much for pointing this out.
We have recorded your feedback and forwarded the correction to our product team.
Thanks again for helping us improve TOS!
Nitrokalel wrote: ↑18 Aug 2026, 03:08
Thank you so much for your suggestion! This feature is already on our roadmap, but it will take some time to implement. Please keep an eye on our announcements.
Nitrokalel
Mexico
Post by Nitrokalel »
TMroy wrote: ↑21 Aug 2026, 18:26
muchas gracias :P
F8 SSD Plus (8x4TB NVMe, TRaid, 48GB, prod)
F8 SSD Plus (6x1TB+2x2TB, TRaid, 48GB, prod)
F4-424 Pro (2x22TB+2x10TB HDD +1TB+500GB NVMe, TRaid, 32GB, prod)
F2-423 (2x18TB, TRaid, 32GB, prod)
F2-221 (6TB+10TB, TRaid, 10GB, prod)
D1 SSD (2TB, prod)
