TOS 7.0.0601 Beta (X86) is Released for Update
storageninja
Netherlands
Re: TOS 7.0.0601 Beta (X86) is Released for Update
Post by storageninja »
Hello TM it’s had been confirmed after a week of monitoring. F4 SSD won’t auto boot at scheduled time. Only shutdown works. Could we investigate, I also reported in another topic about this bug.
storageninja wrote: ↑24 May 2026, 19:16 Hello TM it’s had been confirmed after a week of monitoring. F4 SSD won’t auto boot at scheduled time. Only shutdown works. Could we investigate, I also reported in another topic about this bug.
We will continue to monitor the situation and attempt to reproduce the issue you mentioned.
mossholderm
Post by mossholderm »
Any word on whether the U4-111 will be supported?
Thanks!
This may be due to a mismatch in the time or time zone settings.
If your NAS time is set to “Sync with web browser,” try changing it to “Sync with server.”
EgorA
Post by EgorA »
Thanx!
Top bar now floating over windows to give more space on desktop!
Next step is make bar really floating with the ability to drag it up/down/left/right side of desktop.
Thanx!!
F4-423
storageninja
Netherlands
TMzethar wrote: ↑25 May 2026, 09:01
It is synced with a server. Please note that shutdown as the scheduled time works fine, but startup just not.
Have you tried just running a startup schedule on its own without the shutdown. (Shutdown manually to test). This sounds like an old problem where the "power" scheduled tasks did not gracefully handle multiple (ie more than one!) events. You could of course use the main task scheduler (custom options) to script and sequence these events.
Frustrated Beta Tester!!!
storageninja
Netherlands
Gremlin wrote: ↑26 May 2026, 02:10 Have you tried just running a startup schedule on its own without the shutdown. (Shutdown manually to test). This sounds like an old problem where the "power" scheduled tasks did not gracefully handle multiple (ie more than one!) events. You could of course use the main task scheduler (custom options) to script and sequence these events.
Just tested, only one startup line: does not work, It simply never startup/boot.
snapsh0t
Post by snapsh0t »
storageninja wrote: ↑26 May 2026, 02:45
I had a similar problem and I found that deselecting 'Enable scheduled task', Apply, then selecting it again and Apply fixed it. I expect you've already tried this but if not......
F2-425 Plus (N150), 16GB RAM, 2 x 500GB WD SN700 EXT4 RAID1, 2 x 3TB WD Red EXT4 RAID1, TOS 7.0.<latest>
F4-SSD, 16GB RAM, 4 x 4TB WD SN700 Btrfs TRAID, TOS 7.0.<latest>
storageninja
Netherlands
snapsh0t wrote: ↑26 May 2026, 12:50
Yeah tried that last night also, but no difference.
