TOS 6.0.530 Official Version Released
Felix
Re: TOS 6.0.530 Official Version Released
Post by Felix »
RealGold wrote: ↑16 Jun 2026, 03:53 It is not possible to update my F4 423 from TOS 5.1.145 to TOS 6.0.530. After manual update in release Package 530, F4 423 restarts unregularly and get such info! Hast anyone any idea?
Please check the size of your / directory on this page. If it's around 2GB, the upgrade is not supported. If it's around 8GB, please check if you have enough free space. Note that you have enabled secure isolation mode; please disable it and try again. If you have configured SSD caching, please delete the cache before upgrading.
RealGold
Germany
Post by RealGold »
What is that? How to extend it?
THAT is the assigned operating system partition space. The only way (currently) is to BACKUP ALL YOUR DATA and then install a release version of TOS6 installation or a later version of TOS5 installation (.ins files) available from the main support download files. This will automatically REFORMAT YOUR DRIVES and assign the correct partition spaces for the Operating system.
{It may be helpful to backup system configuration and export user/group lists if you decide to re-instal TOS5 before updating to TOS6.}
Then restore your data.
Frankly, it is surprising that you could run 5.0.145 properly with reduced os partition space. There are plenty of details in the version release files.
EriChan
Post by EriChan »
RealGold wrote: ↑19 Jun 2026, 02:10
That is the system partition allocated to the operating system, and you do not need to expand it manually.
This situation is quite rare and involves many factors. Please contact our online technical support specialists via the link below to book a remote technical support session for diagnosis:https://salesiq.zohopublic.com/signatur ... 97d0be8892
RealGold
Germany
Post by RealGold »
My last attempt with TOS! Xpenology will be the next stop.
RealGold wrote: ↑19 Jun 2026, 23:28
According to the screenshot you provided, Security Isolation Mode​ is currently enabled on your TOS system. You need to disable this mode before proceeding with the system update.
