Urgent Notification about TNAS being Attacked by Ransomware
- Charlie_Croker
Re: Urgent Notification about TNAS being Attacked by Ransomware
LaMosca wrote:
> Charlie_Croker wrote:
> > So you're just posting to say that you blocked a QNAP that was trying to
> > infect your system? Or did it just do a port scan?
> > In the last 3 days according to my IPS . I have had 18 "possible
> > network Intrusion attempts" , numerous "ET Drop Dshields",
> > 17 "ET Scans", 1x attempted information leak".
> > I use Unifi Security Gateway Pro, with a UDM Pro ready to be installed when
> > I get the time. It has very good IPS.
> https://help.ui.com/hc/en-us/articles/3 ... y-Settings
> if I know UniFi.
> very well. it's just that my system is not dependent on any software or platform.
> it is totally independent. and so far without failure.
> and anyone who needs it can use it. It can also forward traffic to my system to block
> intruders. t a few days later you can pick up the block list. which is already big by
> the way.
I have had a few probes round your network, I will stick to Unifi as its kept my network safe for over 6 years. And I need to VPN back to UK from Saudi and the VPN server is great, As a rule (for security reasons and the need to comply with specific standards) I tend not to use untrusted/untested software, has your system had a security audit? Penetration testing?
> if I know UniFi.
> the way.
Charlie_Croker
good what you have implemented at this time. does not prevent you from using this system.
You will see that this system will help you. so that the scans that they do to your ips do not come back. from the same point.
If you want you can contact me by telegram and we can do several tests. together.
You will see how effective the system I have here is.
I help you configure it so you can implement this. apart from what you already have.
in fact the scans to my ips have stopped. because every scan gets worse for the attacker. because the system blocks those ips and then the attacker is finally left with no other pvn to go on.
Contact me and we'll run some tests together if you want.
Charlie_Croker
LaMosca wrote:
> Hello, what I recommend is to talk to the terra master online support, they will help you. Definitely.
Hello, thanx a lot for your help. Where could I find OnLine help ? I only find email adress on the terramaster site, was that the online help perhaps ?
And on my NAS, the trouble make me only enable the remote access for 24/48/78 hours but nothing else accessible (if any).
Thanx.
Thanx.
- Charlie_Croker
> VPN
> specific
> Charlie_Croker
> system.
Your system only blocks an IP, as I have said in the past, I have repeatedly accessed your system (Blocking an IP is not a secure system as they can be spoofed or even just use a VPN), so its not actually blocking an attack, you need to be fingerprinting the device.
And no mate, there's no way in hell I would rely or let loose on my networks something that's unproven, by someone I only know from an Internet forum, my data is far too important for that. For all I know you are a black hat and there's a greta big back door or some other vulnerability.
And what makes you think your system supplements a proper iPS? It appears to be script based.
My feeling is your system is actually making it less secure, as if I was that way inclined, I would be trying to break in to it for the challenge.
But if it works for you and you are happy with it, then whatever floats your boat.
> VPN
> specific
> Charlie_Croker
> system.
> script based.
Exactly!
Unsolicited offers from unknown sources.
> script based.
Exactly!
> data is
> greta
> > script based.
> way
> boat.
> Exactly!
I said way back through the posts, about the irony of a thread relating to attacks and people clicking on an unknown link 'cos someone said "try it out" :D
> data is
> greta
> > script based.
> way
> boat.
> Exactly!
The antivirus ClamAV in your TNAS
ClamAV anti virus
El antivirus que esta en Tu TNAS. lo puedes encontrar aqui para Win32, MacOS X, Linux
The antivirus that is in your TNAS. you can find it here for Win32, MacOS X, Linux
http://www.clamav.net/downloads
Coin mining with your terramaster
Coin mining with your terramaster?
I was able to verify that my TNAS. you are trying to connect to a mining site. Here I leave you the test to check your terramaster.
place your terra-master behind a firewall so you can check the IP addresses your terra-master is trying to connect to.
notify: We will continue to develop safer and more efficient fund settlement channels for everyone to use, thank you for your support! Star map 2022/02/11
CPU mining pool notification: urgent notification, due to force majeure, multiple IPs in the machine gun pool have been disabled, please use auto.c3pool.org in time: the port remains unchanged!
通知:我们将继续开发更安全、更高效的资金结算渠道供大家使用,感谢您的支持! 星图 2022/02/11
CPU矿池通知:紧急通知,由于不可抗力,机枪池多个IP已被禁用,请及时使用auto.c3pool.org:端口不变!
Check this site.
https://c3pool.com
https://auto.c3pool.org
auto.c3pool.org
My Terramaster Information
2022-03-17 08:16:05 Local User (MAC=xx-xx-xx-xx-xx-xx): 10.0.2.8 DNS -> 66.159.32.35 inquire auto.c3pool.org
I will make a detailed report of the situation to the investigative group of Terra-master
Check this site.
https://c3pool.com
auto.c3pool.org
- Charlie_Croker
LaMosca wrote:
Why do you keep posting links that you want us all to click? It seems very suspicious.
