TOS 6.0.555 (X86) is Released for Update
ORION
Re: TOS 6.0.555 (X86) is Released for Update
Post by ORION »
updated from 5.1.145 to 6.0.530 and immediately he found a new update to 6.0.555 everything went without problems! the IP has not changed, the files are all in place, I just re-configured some system settings, the total time is no more than 40 minutes.
F4-424 Pro :roll:
F2-210 :D
mrslother
Post by mrslother »
mrslother wrote: 08 Dec 2024, 13:49 Active Directory problem after upgrading from 6.0.535.
My Active Directory domain was not enabled (checkbox in Settings--> Domain --> Join Domain option is not checked).
What has changed since 6.0.535??
I modified the /etc/samba/smb-ads.conf file with
workgroup = MYDOMAIN
but while trying to rejoin the domain TOS keeps rewriting that line to
workgroup = INTRA
It looks like TOS is pulling my configured AD domain ("intra.mydomain.com") and just extracting the "intra" from it.
That would be a regression from 6.0.535.
Why is this happening?
redbad
Poland
Post by redbad »
F5-221 updated without issues
ColaChen
Post by ColaChen »
mrslother wrote: 09 Dec 2024, 05:49
Hi.
Did you only change the value of "workgroup=MYDOMAIN" on 6.0.535? Are there any other configurations? Our lab will verify whether the situation you described exists. Thank you.
mrslother
Post by mrslother »
TMcola wrote: 09 Dec 2024, 20:04 Did you only change the value of "workgroup=MYDOMAIN" on 6.0.535?
I don't know what the contents of smb-ads.conf was back in 535 but the NAS was properly joined to the domain and reflected the "MYDOMAIN" workgroup. After updating to 555:
  • The Network Services --> SMB File Service config still showed workgroup/domain as: "MYDOMAIN"
  • The Privileges --> Domain join checkbox was no longer checked. When manually checking the config options were already present in the edit fields; the domain showed "intra.mydomain.com" as expected. And the advanced settings showed workgroup of "MYDOMAIN" as expected.
I only noticed that /etc/samba/smb-ads.conf contains "INTRA" only after the domain re-join failure. I don't know what it had before I tried re-joining the domain.
If I change it to "MYDOMAIN" and try re-joining it always is rewritten to say "INTRA".
TMlinda
Post by TMlinda »
mrslother wrote: 10 Dec 2024, 06:49
This issue has been verified in our laboratory and is being resolved. Please wait for the release of the next system version.
mrslother
Post by mrslother »
Thank you for your fast response to this issue.
Digit
Post by Digit »
I have an issue everyday after scheduled reboot.
I am using rsync service only and the latest is not restarting properly.
The /etc/rsyncd.conf is not rebuilt correctly... when I go in the UI and define the rsync service, I get this rsyncd.conf:
log file = /var/log/rsyncd.log
pid file = /var/run/rsyncd.pid
lock file = /var/lock/rsync.lock
use chroot = no
max connections = 5
read only = no
write only = no
list = no
ignore errors = yes
#motd file = /etc/rsyncd.motd
#exclude =
uid          = david
gid          = david
port         = 873
auth users   = nas_backup
secrets file = /etc/rsyncd.passwd
        [backup_VM]
        path = /Volume1/backup_VM
        list = yes
        [backup_homes]
        path = /Volume1/backup_homes
        list = yes
        [backup_scans]
        path = /Volume1/backup_scans
        list = yes
However, after a scheduled reboot, it looks invalid (uid empty, git instead of gid and empty):
use chroot = no
max connections = 5
read only = no
write only = no
list = no
ignore errors = yes
#exclude =
uid =
git =
port         = 873
        [backup_VM]
        list = yes
        [backup_homes]
        list = yes
        [backup_scans]
        list = yes
Could you please fix this asap as it's the only reason for me to have bought this nas (backup my primary nas through rsync)
TMlinda
Post by TMlinda »
Digit wrote: 10 Dec 2024, 19:15
Thanks for your feedback, we will verify whether this issue exists in our lab.
addx972
France
Post by addx972 »
ORION wrote: 09 Dec 2024, 02:30
thank you for your message i made the update and everything is working for me ;)
