It was written somewhere in one of the replys that you have to do it manualy.
TOS 5.1.145 (X86) is Released for Update
Re: TOS 5.1.145 (X86) is Released for Update
F2-423 2x4TB
You can refer to the following link for your device model: viewtopic.php?t=6809
- lichkingxxl
- monkeyboy72
F4-220 "failed to update"
Rebooted and tried again, same error. Currently running 5.1.131 with 8gb partition.
Is there an update log to show why?
(And I assume this model won't get a TOS 6?)
It may be that the network connection is not smooth. Please check the network connection, or try to download TOS5.1.145 in advance and upload it manually to execute the installation.
There may be insufficient space on the volume. Please reserve a large enough space to temporarily store and run the TOS update package.
There may be a file system error in the volume. Please try to check and fix it:
viewtopic.php?t=2575
The F4-220 does not support TOS6.
