I didn't get an email, just a popup notification today when I logged into the NAS.
TOS 6 Insider Preview Program
Re: TOS 6 Insider Preview Program
AHH mines in security isolation mode.... I will allow it to connect to the internet. Thanks.
My TNAS
- Device = T6-423
- RAM = 32gb official Terramaster ram
- Disks = 3 x Seagate IronWolf ST400VN006 4TB
- TOS = 7.0.1163
- BIOS = 5.19
- Mobile App = 3.5.0.81
Re: TOS 6 Insider Preview Program - 6.0.124 Update
Ran the update today and no issues during the process. Took about 8 minutes to be fully up and running.
Observations:
Login to the webgui is much faster, there used to be a delay between the desktop showing and the app bar at the top. That delay is gone now.
Running state CPU seems to be about 5% lower
Observations:
How can I get a copy installed?
- crisisacting
- Silver Member
Refer back to & read the first post. If they choose you (post contest), they provide instructions via email to participate in this preview.
- sirotkaslo
Does anyone have a problem with enabling certain apps? I can't enable surveillance manager and virtualbox. I'm running the latest version of tos 6 on my F4-423 nas.
The surveillance manager works perfectly for me, as does the remote access to the program! Try reinstalling to see if that fixes the problem. I don't use Virtualbox.sirotkaslo wrote: ↑12 Dec 2023, 15:23 Does anyone have a problem with enabling certain apps? I can't enable surveillance manager and virtualbox. I'm running the latest version of tos 6 on my F4-423 nas.
Yes. But sometimes the app works even if it reports "operation failed" when enabling.sirotkaslo wrote: ↑12 Dec 2023, 15:23 Does anyone have a problem with enabling certain apps? I can't enable surveillance manager and virtualbox. I'm running the latest version of tos 6 on my F4-423 nas.
I still can't get the web server to work, does anyone have this working or is it just me?
- sirotkaslo
It did indeed work, but couldn't get it to connect to my cam. I have Dahuas with ONVIF enabled.Gremlin wrote: ↑12 Dec 2023, 17:52Yes. But sometimes the app works even if it reports "operation failed" when enabling.sirotkaslo wrote: ↑12 Dec 2023, 15:23 Does anyone have a problem with enabling certain apps? I can't enable surveillance manager and virtualbox. I'm running the latest version of tos 6 on my F4-423 nas.
