TOS 5.1.79 (X86) is Released for Update
Alessio71
Italy
Re: TOS 5.1.79 (X86) is Released for Update
Post by Alessio71 »
{L_BUTTON_AT}ostaporomo
Do you think that changing the way the date is displayed it will fix the issue with the scheduled power up?
Thank you
ostaporomo
Finland
Post by ostaporomo »
[at=Alessio71 post_id=30541 time=1698001813 user_id=5675][/at]
After changing the date display format, my NAS turns off and turns on according to the script without any failures or problems.
Try it, you will succeed.
If developers cannot release software without such annoying errors, we ourselves must help each other and restore the operation of our NAS :)
TNAS F2-223
TOS 5.1.79-00214
2x RAM Samsung 16GB DDR4 2133 MHZ
2x HDD Segate IronWolf ST4000VN008 4TB [RAID1]
DAS D4-300
2x HDD Seagate SkyHawk ST3000VX010  [RAID1]
2x HDD Toshiba DT01 DT01ACA300-3TB
{L_BUTTON_AT}jgea
I understand from your past speech records that you are using the F4-421 model and have used TOS4. The system partition is still 2GB that is incompatible with the newer TOS5 version. Please refer to this to troubleshoot the problem:viewtopic.php?f=28&t=4912
philou669
Post by philou669 »
philou669 wrote: ↑22 Oct 2023, 01:49 I don't have english or french option anymore. I have just languages that are foreign to me.
help me please
{L_BUTTON_AT}philou669
We have not verified and observed feedback from other users regarding this issue. We have noticed that you may still be using the 2GB system partition. Please also refer to this for installing the appropriate TOS version or adjusting storage:viewtopic.php?f=28&t=4912
yak983
Post by yak983 »
white page
Request URL:
http://192.168.1.111:8181/v2/lang/tos
Request Method:
GET
Status Code:
502 Bad Gateway
Remote Address:
192.168.1.111:8181
{L_BUTTON_AT}yak983
ostaporomo
Finland
Another bug of the new firmware.
When using the scheduled on/off function, when the system is turned on, the disks installed in the D 4-300 do not start up randomly (the D 4-300 is connected to the F2-223, two disks in ride 1, one for torrents and one for file storage).
I rechecked the status of the disks using the Victoria program. No errors found.
There were no such problems on TOS 5.1.67 firmware.
Dear developers, please tell me how to return to TOS 5.1.67 firmware from TOS 5.1.79?
TNAS F2-223
TOS 5.1.79-00214
DAS D4-300
yak983
Post by yak983 »
{L_BUTTON_AT}yak983
TMzethar wrote: ↑24 Oct 2023, 18:47 We have noticed that you may still be using the 2GB system partition. Please also refer to this for installing the appropriate TOS version or adjusting storage:viewtopic.php?f=28&t=4912
i have 58TB of data so i can't delete the partition to make 8gb partition Filesystem Size Used Avail Use% Mounted on /dev/md9 1.9G 1.8G 0 100% / devtmpfs 2.8G 0 2.8G 0% /dev tmpfs 2.9G 0 2.9G 0% /dev/shm tmpfs 2.9G 15M 2.9G 1% /tmp tmpfs 2.9G 56K 2.9G 1% /run tmpfs 2.9G 3.4M 2.9G 1% /opt/var /dev/mapper/vg0-lv0 58T 57T 730G 99% /Volume1 how i can rollback?
{L_BUTTON_AT}yak983
If you are unable to backup them, it is recommended to keep using TOS 5.124 and earlier versions. You can obtain the installation package from the download center.
