TOS 5.1.41 (X86) is Released for Update
Re: TOS 5.1.41 (X86) is Released for Update
Re: Scheduled Startup/Shutdown - Slow transfer speeds
Don't know if this is a clue:
[332618.119964] hpet: Lost 7161 RTC interrupts
[332619.249713] hpet: Lost 7161 RTC interrupts
[332620.377823] hpet: Lost 7160 RTC interrupts
[332621.488050] hpet: Lost 7161 RTC interrupts
[332622.635306] hpet: Lost 7161 RTC interrupts
[332623.768783] hpet: Lost 7161 RTC interrupts
[332624.899920] hpet: Lost 7161 RTC interrupts
[332626.033064] hpet: Lost 7161 RTC interrupts
[332627.168708] hpet: Lost 7161 RTC interrupts
[332628.297503] hpet: Lost 7160 RTC interrupts
[332629.425464] hpet: Lost 7161 RTC interrupts
[332630.552225] hpet: Lost 7161 RTC interrupts
[332631.681454] hpet: Lost 7161 RTC interrupts
[332632.811269] hpet: Lost 7161 RTC interrupts
[332633.935842] hpet: Lost 7161 RTC interrupts
[332635.061693] hpet: Lost 7161 RTC interrupts
[332636.198401] hpet: Lost 7161 RTC interrupts
[332637.327734] hpet: Lost 7161 RTC interrupts
[332638.455454] hpet: Lost 7161 RTC interrupts
[332639.580462] hpet: Lost 7161 RTC interrupts
[332640.708072] hpet: Lost 7160 RTC interrupts
[332641.839916] hpet: Lost 7160 RTC interrupts
[332642.968147] hpet: Lost 7161 RTC interrupts
[332644.093201] hpet: Lost 7161 RTC interrupts
[332645.220317] hpet: Lost 7161 RTC interrupts
[332646.345499] hpet: Lost 7161 RTC interrupts
[332647.477100] hpet: Lost 7161 RTC interrupts
[332648.602670] hpet: Lost 7161 RTC interrupts
[332649.730262] hpet: Lost 7161 RTC interrupts
[332650.851066] hpet: Lost 7161 RTC interrupts
Pages and pages when it happens.
would you login ssh, and send us the output by command line: cat /proc/cmdline
{L_BUTTON_AT}TMroy
cat /proc/cmdline = BOOT_IMAGE=/boot/bzImage type=raid
The output shows that the configuration is incorrect.
Would you remove all your drives and reboot your TNAS to find the initboot version number from the bottom of the TOS page? appreciate!
After that you need to shut down your TNAS, insert your drives back into the box, and reboot again, then you can come back to your running system.
{L_BUTTON_AT}TMroy
What would be "correct"?
Correct configuration: hpet=disable
We will verify and provide a solution to this issue.
Thanks. I'll get back to you with initboot info as soon as I can.
{L_BUTTON_AT}TMroy
Bootloader version 1.0.4
Initboot(?): J3355_MAPL0304V22_V5.1.44
Trust that is what you wanted.
Yes, thank you.
I can confirm SMB was disabled after restart following above shutdown/restart
