Plex HW Transcoding in TOS 5.1
Re: Plex HW Transcoding in TOS 5.1
I will step in for this.
When someone say that harware transcoding is not working on TOS5, it should also specify the NAS model as we have different situations now.
- For the new models with JasperLake CPU N5095/N4505 (Fx-x23, Tx-x23), hardware transcoding is broken in TOS 5.1 and TM have to fix it probably with a new kernel.
- For the older models, hardware transcoding is broken due to a missing parameter in Plex startup script (to be fixed by plex)
This can also be fixed by users with SSH knowledge, the issue is that the plex user is not added to the video group which have access to video card.
Is a one time change.
In order to fix it, connect with SSH and:
- check if the user plex is already part of the video group
id "plex" | grep "(video)"
If you don't get a return message, run the command to add the plex user to video group
usermod -aG video "plex"
Check again if the change was done
An you should get the message below, the group is iportant
uid=1009(plex) gid=6(media) groups=6(media),28(video)
Restart plex and hardware transcoding should work
Apr 12, 2023 20:04:59.436 [0x7efd6c042b38] INFO - Plex Media Server v1.31.2.6783-9209b39b4 - TerraMaster TNAS F2-221 x86_64 - build: linux-x86_64 terramaster-tos5 - GMT 08:00
Apr 12, 2023 20:04:59.437 [0x7efd6c042b38] INFO - Linux version: TOS 5.1.31-00348, language: en-US
Apr 12, 2023 20:04:59.437 [0x7efd6c042b38] INFO - Processor: 2-core Intel(R) Celeron(R) CPU J3355 @ 2.00GHz
Apr 12, 2023 20:05:59.567 [0x7efd691e7b38] DEBUG - [Req#18b/Transcode] TPU: hardware transcoding: using hardware decode accelerator vaapi
Apr 12, 2023 20:05:59.567 [0x7efd691e7b38] DEBUG - [Req#18b/Transcode] TPU: hardware transcoding: zero-copy support present
Apr 12, 2023 20:05:59.567 [0x7efd691e7b38] DEBUG - [Req#18b/Transcode] TPU: hardware transcoding: using zero-copy transcoding
Apr 12, 2023 20:05:59.568 [0x7efd691e7b38] DEBUG - [Req#18b/Transcode] [Universal] Using local file path instead of URL: /Volume1/Movies/
Apr 12, 2023 20:05:59.568 [0x7efd691e7b38] DEBUG - [Req#18b/Transcode] Codecs: hardware transcoding: testing API vaapi
Apr 12, 2023 20:05:59.571 [0x7efd691e7b38] DEBUG - [Req#18b/Transcode] [FFMPEG] - Format 0x32315659 -> yuv420p.
Apr 12, 2023 20:05:59.571 [0x7efd691e7b38] DEBUG - [Req#18b/Transcode] [FFMPEG] - Format 0x30323449 -> yuv420p.
Apr 12, 2023 20:05:59.571 [0x7efd691e7b38] DEBUG - [Req#18b/Transcode] [FFMPEG] - Format 0x3231564e -> nv12.
Apr 12, 2023 20:05:59.571 [0x7efd691e7b38] DEBUG - [Req#18b/Transcode] [FFMPEG] - Format 0x32595559 -> yuyv422.
Apr 12, 2023 20:05:59.571 [0x7efd691e7b38] DEBUG - [Req#18b/Transcode] [FFMPEG] - Format 0x59565955 -> uyvy422.
Apr 12, 2023 20:05:59.571 [0x7efd691e7b38] DEBUG - [Req#18b/Transcode] [FFMPEG] - Format 0x48323234 -> yuv422p.
Apr 12, 2023 20:05:59.571 [0x7efd691e7b38] DEBUG - [Req#18b/Transcode] [FFMPEG] - Format 0x58424752 -> rgb0.
Apr 12, 2023 20:05:59.572 [0x7efd691e7b38] DEBUG - [Req#18b/Transcode] [FFMPEG] - Format 0x58524742 -> bgr0.
Apr 12, 2023 20:05:59.572 [0x7efd691e7b38] DEBUG - [Req#18b/Transcode] [FFMPEG] - Format 0x30313050 -> p010le.
Apr 12, 2023 20:05:59.572 [0x7efd691e7b38] DEBUG - [Req#18b/Transcode] [FFMPEG] - Created surface 0x4000000.
Apr 12, 2023 20:05:59.572 [0x7efd691e7b38] DEBUG - [Req#18b/Transcode] [FFMPEG] - Direct mapping possible.
Apr 12, 2023 20:05:59.573 [0x7efd691e7b38] DEBUG - [Req#18b/Transcode] TPU: hardware transcoding: final decoder: vaapi, final encoder: vaapi
iacutone
Post by iacutone »
Model: F2-243
TOS: 5.1.31
Plex Media Server: 1.32.0.6918 with Plex Pass Lifetime
I have followed the steps that you indicate. After execute
usermod -aG video "user"
id "user" | grep "(video)"
I get these values:
uid=0(user) gid=0(user) groups=0(user),3(admin),4(allusers),28(video)
If I understand correctly I must set:
PUID=0
PGID=0
Does not work for me
Far as i know there is no model F2-243, so i guess you wanna say F2-423 or F2-223.
Check my post again.
Your model is part of the Fx-x23 series with JasperLake CPU.
Hardware transcoding is currently not working on TOS 5.1 with the current kernel version or the existing kernel parameters.
jhalfhide
Post by jhalfhide »
Plex Hardware Transcoding still not working despite adding Plex to the Video group and restarting the Plex application. This is TOS 5.1.29, on a F2-422.
F2-422 running TOS 5.1
Plex/Sonarr/Radarr/Lidarr/SabNZBD
iacutone
Post by iacutone »
outkastm wrote: ↑13 Apr 2023, 03:49 Far as i know there is no model F2-243, so i guess you wanna say F2-423 or F2-223.
Yes, my model is F2-223.
Ok, I thought that with the command you indicated it could be activated.
jhalfhide
Post by jhalfhide »
Checking the console in Plex, I now do see Hardware transcoding messages since doing the video group add. I see this...
[Req#11902/Transcode] Codecs: hardware transcoding: testing API vaapi
[Req#1191c/Transcode] TPU: hardware transcoding: enabled, but no hardware decode accelerator found
[Req#1191c/Transcode] TPU: hardware transcoding: final decoder: , final encoder:
jhalfhide wrote: ↑13 Apr 2023, 04:02 Plex Hardware Transcoding still not working despite adding Plex to the Video group and restarting the Plex application. This is TOS 5.1.29, on a F2-422.
This definetly should work, your NAS have an Apollo Lake CPU J3455, same family as my testing F2-221 with Apollo lake CPU J3355.
Do you have a Plex Pass ? Enable plex debug log and check for hardware string
StephenNaylor
Post by StephenNaylor »
In case it helps anyone, my plex is showing that new server updates are available with these release notes...
Version 1.32.1.6999
New
(Logging) Transient and per-startup local admin tokens are now fully redacted in logs by default (#13986)
Fixes
(Credits Detection) Detection could sometimes use the incorrect stream information (#14216)
(Downloads) Transcoded downloads counted against per-user streams (#14139)
(Plugins) Secure connection requests would fail to load on Windows machines (#14279)
(TerraMaster) Improve hardware transcoding compatibility on TOS 5 platform
spotpuff
Post by spotpuff »
This still seems to be broken on the latest Plex Server as of this date for TOS 5 (Version 1.32.2.7100).
Is it working for everyone else? I am still on TOS 5.0.whatever because the later updates killed my network transfer speeds.
StephenNaylor
Spotted this in the release notes for ToS 5.1.33
"The kernel of TOS 5.1 has been updated to 5.15. Since the Linux kernel has removed the Intel Celeron J1800/J1900 GPU drivers from 5.15, the models of this platform no longer support GPU hardware video acceleration. If you are a user of this series of models and need to use GPU hardware video acceleration, do not update TOS 5.1! Models involved: F2-220/F2-420/F4-220/F4-420/F5-420"
I assume that this will be the cause of the issue if you are on these models: F2-220/F2-420/F4-220/F4-420/F5-420
Return to “Plex Media Server”
