TOS 4.2.16 is released for update!
Re: TOS 4.2.16 is released for update!
{L_BUTTON_AT}Budo68
Hi! Judging from your screenshot, there is an error in the system. It is recommended that you reinstall the system. viewtopic.php?f=75&t=423
Saijin_Naib
Post by Saijin_Naib »
Worked great on my F2-210, so thanks for that!
Only a few settings got reset, namely my port for secure HTTPS access and SMB Workgroup name.
myrix
Post by myrix »
Hi.
How can i upgrade my TOS via SSH *without* wiping my data because i got:
"502 Bad Gateway
nginx/1.18.0"
Regards myrix
TMnorah
Post by TMnorah »
If you get a 502 bad gateway error and you cannot log in to the TOS webpage after updating TOS,It may be that the nginx service has not been activated successfully. you can try to log in using SSH, and then restart nginx by referring to the following command to manually start the service.
/etc/init.d/nginx stop
/etc/init.d/nginx start
myrix
Post by myrix »
TMnorah wrote: 17 Oct 2021, 13:17 Hi,
bash /etc/init.d/nginx stop
/etc/init.d/functions: line 611: /var/log/scripts.log: Permission denied
rm: remove write-protected regular file '/var/run/nginx.pid'?
bash /etc/init.d/nginx start
start-stop-daemon: unable to open pidfile '/var/run/nginx.pid' for writing (Permission denied)
start-stop-daemon: child returned error exit status 2 (Permission denied)
bash sudo /etc/init.d/nginx restart
nginx: [warn] the "ssl" directive is deprecated, use the "listen ... ssl" directive instead in /etc/nginx/nginx.conf:64
Tryin to connect via https:
Fehlercode: SSL_ERROR_RX_RECORD_TOO_LONG
/var/log/nginx/error.log
2021/10/17 16:59:16 [warn] 2562#2562: the "ssl" directive is deprecated, use the "listen ... ssl" directive instead in /etc/nginx/nginx.conf:64
2021/10/17 17:00:01 [crit] 2587#2587: *1 connect() to unix:/tmp/php-fpm.sock failed (2: No such file or directory) while connecting to upstream, client: 192.168.178.24, server: znasnginx, request: "GET / HTTP/1.1", upstream: "fastcgi://unix:/tmp/php-fpm.sock:", host: "192.168.178.27:8181", referrer: "192.168.178.27/"
2021/10/17 17:00:01 [error] 2587#2587: *3 open() "/usr/www/favicon.ico" failed (2: No such file or directory), client: 192.168.178.24, server: znasnginx, request: "GET /favicon.ico HTTP/1.1", host: "192.168.178.27:8181", referrer: "192.168.178.27:8181/"
2021-10-17 16:59:10|unnpd|stop unnpd failed|1
2021-10-17 16:59:16|nginx|run nginx success|0
2021-10-17 16:59:59|samba|run samba success|0
2021-10-17 17:00:01|samba|run samba success|0
Regards
{L_BUTTON_AT}myrix
Hi! You cannot restart nginx directly, you need to stop nginx first, and then start nginx.
sudo /etc/init.d/nginx stop
sudo /etc/init.d/nginx start
myrix
Post by myrix »
executable without problems, but still 502 ;(
user root root;
worker_processes  4;
error_log  /var/log/nginx/error.log warn;
pid        /var/run/nginx.pid;
worker_rlimit_nofile 51200;
events {
    use epoll;
    worker_connections  512;
http {
    include         mime.types;
    #include	    fastcgi.conf;
    default_type  	application/octet-stream;
    #fastcgi_cache_path /tmp/php_cache  levels=1:2  keys_zone=cache_php:30m inactive=10s max_size=64m;
    #log_format  main  '$remote_addr - $remote_user [$time_local] "$request" '
    #                  '$status $body_bytes_sent "$http_referer" '
    #                  '"$http_user_agent" "$http_x_forwarded_for"';
    include nginx-http.conf;
    upstream unix_php_cgi_sock{
        server unix:/tmp/php-fpm.sock;
    #HTTP server
    server {
		listen 8181;
        include nginx-ipv6.conf;
        server_name znasnginx;
        root   /usr/www/;
        index  index.html index.htm index.php;
        access_log  /var/log/nginx/access.log;
        #error_page  404              /404.html;
        include		conf.d/*.conf;
        include		nginx-extend.conf;
        # phpBB3, important Flag...don't delete me!!!
        location ~ \.php(.*)$ {
            keepalive_timeout 75;
            fastcgi_pass   unix_php_cgi_sock;
            fastcgi_index  index.php;
            fastcgi_split_path_info  ^(.+\.php)(/.*)$;
            fastcgi_param  SCRIPT_FILENAME  $document_root$fastcgi_script_name;
            fastcgi_param  PATH_INFO  $fastcgi_path_info;
            fastcgi_param  PATH_TRANSLATED  $document_root$fastcgi_path_info;
            include        fastcgi_params;
            fastcgi_param  HTTPS   off;
    #HTTP server
    #HTTPS server
    server {
        listen	5443;
        include nginx-ipv6-https.conf;
        root   /usr/www/;
        ssl	on;
        ssl_certificate      /etc/nginx/tnas.link.crt;
        ssl_certificate_key  /etc/nginx/tnas.link.key;
        ssl_session_timeout  5m;
        ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
        ssl_ciphers ECDHE-RSA-AES128-GCM-SHA256:ECDHE:ECDH:AES:HIGH:!NULL:!aNULL:!MD5:!ADH:!RC4:!DH:!DHE;
        ssl_prefer_server_ciphers   on;
            fastcgi_param	HTTPS	on;
    #HTTPS server
Regards
{L_BUTTON_AT}myrix
Hi! Please try to restart the PHP service.
sudo /etc/init.d/php-fpm restart
scoobyfizz
Post by scoobyfizz »
People should not be getting errors everytime they update, they also should certainly not be having to SSH to their nas and correct things..
Anyhow I will take my hat and leave now as my terramaster has gone to someone on ebay who does not know what they have let themselves in for.. and once again.. admins please delete my account...
Best thing I ever did was ebay my Terramaster...
myrix
Post by myrix »
TMSupport wrote: 19 Oct 2021, 12:15
-bash-4.4$ sudo /etc/init.d/php-fpm restart
Password:
/etc/init.d/php-fpm: line 13: /etc/profile: No such file or directory
vi /etc/profile
%empty%
Regards
