[ jDownloader ] download management tool
Hardfecx
Re: [ jDownloader ][2.00.03] download management tool
Post by Hardfecx »
Pavulon wrote: ↑28 Oct 2021, 05:21 Hi.
Im new with terramaster and wondering about one thing :)
Question about download folder. Each file that has been downloaded is invisible in the folder. Jdownloader shows that the download is complete but when i open the folder...it is empty. When I download it again to the same folder, Jdownloader says that the one copy is already there. I dont know what the reason is. I would be grateful for any tips/help.
Try to change the download folder, like "/mnt/public/Download" in the Options of JDownloader
In seetings change the download folder to
/mnt/appdata/Downloads
or like @Hardfecx sugested if you want to be public
Pavulon
Post by Pavulon »
Thanks guys, works great :)
F2-210
spotpuff
Post by spotpuff »
Couldn't get this working on F5-422.
TOS 4.2.18-2110301149
the application installs but it won't start. The Log Files shows the following error:
<br />
<b>Warning</b>: fopen(/usr/local/jDownloader/bin/LOG/Log.L.log.0): failed to open stream: No such file or directory in <b>/usr/www/modules/jDownloader/www/6.php</b> on line <b>91</b><br />
Do you have the Java dependency installed?
viewtopic.php?f=37&t=1443
spotpuff
Post by spotpuff »
outkastm wrote: ↑10 Dec 2021, 14:15 Do you have the Java dependency installed?
I didn't; I'll give that a try
Hardfecx
Post by Hardfecx »
May someone send me the "Configuration Files" Script to login (without you e-mail and password), in my jdownloader it is empty sindy I reinstall everything!
Thank you in advance!
  "password" : "",
  "email" : ""
Hardfecx
Post by Hardfecx »
{L_BUTTON_AT}outkastm
Thank you M8!
xustis
Post by xustis »
I haven't used it for a long time, but today I have problems, the application seems to be running all the time but in the web interface the "server" appear and disappear
