[ Cron_okm ] Time-based job scheduler
waltools
Re: [ Cron_okm ] Time-based job scheduler
Post by waltools »
#UPDATE
after some time I found the solution... the key is to use absolute path for all apps involved.
crontab:
@reboot wendhausen /Volume1/User/wendhausen/\[raid\]/\[system\]/onboot.sh ps3netsrv
script:
/Volume1/@apps/Tmux/sys/bin/tmux new-session -d -s onboot '/home/wendhausen/[raid]/games/Playstation/ps3netsrv_linuxX86_64 /home/wendhausen/[raid]/games/Playstation/ 38008 *.*.*.*'
now it is scalable.
:D
Madvic
Spain
Post by Madvic »
The tool isn't working, that is, no schedules are triggered. I should be doing something wrong but I don't know what.
Product: F2-221
TOS version: 5.0.176-00227
Cron_okm version: 1.5.7.1
These are the two crontab lines I configured:
*/15 * * * * <absolute_path>/CopyToOneDrive.sh
*/5 * * * * <absolute_path>/SyncToOneDrive.sh
The intent is to have one executed every 15 minutes and the other every 5 minutes
The Daemon is running and auto start is enabled.
Edit: Regular cron (using crontab -e from command line) works well
The app is working, I guess you haven't read the complete topic to see what you did wrong
viewtopic.php?f=37&t=1821&start=20#p24709
Madvic
Spain
Post by Madvic »
Indeed, dumb me :-)
mmedic
Post by mmedic »
Hi! Thank you for the great app. Am I right in understanding that "crontab -e" schedule script will be automatically executed after reboot or I should add it into system boot sequence? I faced the issue that cron-okm cannot be enabled on latest TOS6 after beeing successfully installed via tpk file.
F4-424, actual TOS6
Scottnorwo
Post by Scottnorwo »
tos 6 soon??
Will be done asap
Mikmak2000
Bonaire
Post by Mikmak2000 »
It seems the v6 version is done by looking at the Apps page, but the page does not link to the file.
If I try v5 on TNAS v6 it installs but cannot start.
brunix86
Italy
Post by brunix86 »
outkastm wrote: ↑28 Mar 2025, 03:26 Will be done asap
Hi outkastm,
I see that the app is compatible with TOS6, but there is no link about that version:
Could you kindly check links?
My NAS Environment
  • TNAS F4-424
  • TOS 7.0.1536 (8GB System Partition)
  • 1x RAM Terramaster 8GB DDR5 4800 MHZ
  • 2x HDD Seagate IronWolf 12TB CMR [RAID1]
It was up to 6.0.420. I need to create a new app for newer TOS6
