[Midnight Commander WEB ] (CLI) File explorer
lkss
Re: [Midnight Commander WEB ][ 4.8.27.1 ] File explorer
Post by lkss »
Thank You!
But it doen't work :roll:
I"ve installed it, but it does'nt drop icon on desktop and I find in app center in off-mode.
When I try to run it - system refuse it (writes "operation failure")
Model F5-221, tos5 ver. 5.0.171-00221
Do you have the latest ModBase1 app installed?
davidecavestro
Italy
Post by davidecavestro »
It doesn't work on my F2-223 with TOS 1.5.40, so as of now I am going with a /usr/local/bin/mc script like this
#!/bin/bash
docker run --rm -it \
  -v /Volume1:/Volume1 \
  -v $HOME/.config/mc/:/root/.config/mc \
  blackvoidclub/midnight-commander \
It works fine if you have all the dependencies installed.
Saying only is not work is not enough to troubleshoot
davidecavestro
Italy
outkastm wrote: 09 Sep 2023, 16:31 It works fine if you have all the dependencies installed.
You are right, I didn't install ModBase1.
Vif
Afghanistan
Re: [Midnight Commander WEB ] (CLI) File explorer
Post by Vif »
Dear OutkastM, Sorry for the off-topic, I think you were once the developer of the Midnight commander app for Thecus NAS? I have N2810 with OS7. I used to use MC with pleasure, but now they removed it from the list of supported applications. Could you kindly tell me where I can download an old copy of the package for manual installation MC_4.8.18.2_x64_OS5_OS7.mod
thanks!
I'll check if I still have the package
Vif
Afghanistan
Post by Vif »
outkastm wrote: 14 Aug 2024, 16:54 I'll check if I still have the package
Thanks! Will wait your message!
tommi64
Germany
Post by tommi64 »
Is there a version for TOS5 under armv8.2 available somewhere?
MC_TOS4_4.8.27.1_aarch64.tpk doesn't work.
ModBase1 TOS5 1.00.04 aarch64.tpk is installed.
I need this for an F4-212.
There will be a version available for TOS6
