[ Nextcloud ] Self-hosted productivity platform
Roccia7
Italy
Re: [ Nextcloud ][ 23.0.0.1 ] Self-hosted productivity platform
Post by Roccia7 »
Hi, is it possible to store data in: /mnt/md0 ?
TNAS F2-220
TOS 5.0.176
Roccia7
Italy
Post by Roccia7 »
outkastm wrote: ↑07 Jan 2022, 03:58yes
Thanks but i tried when i configured the app and I could not use that folder. I tried to modify it in configuration file and nextcloud doesn't work. So, please, how can i do?
TNAS F2-220
TOS 5.0.176
only root user has write access to /mnt/md0
So before Nextcloud setup, you have to create the folder for NextcloudDATA and change the owner of this folder to user www-data
Connect using ssh and run
[user@TNAS-xxxx md0]$ cd /mnt/md0
[user@TNAS-xxxx md0]$ sudo mkdir -p /mnt/md0/NextcloudDATA
Password:
[user@TNAS-xxxx md0]$ sudo chown www-data:www-data NextcloudDATA
[user@TNAS-xxxx md0]$ ls -ld NextcloudDATA
drwxr-xr-x 2 www-data www-data 4096 Jan  6 22:32 NextcloudDATA
then you can use /mnt/md0/NextcloudDATA during setup
Roccia7
Italy
Post by Roccia7 »
outkastm wrote: ↑07 Jan 2022, 05:44 only root user has write access to /mnt/md0
Password:
Thanks a lot for your explanation, so if i would share files i need to use mnt/md0/NextcloudDATA folder, right? But if i would share all md0 folder? Is it possible?
TNAS F2-220
TOS 5.0.176
Nextcloud is working as a cloud server. You cannot choose a folder during installation and to make all content available inside nextcloud. The folder choosed consider it as a drive, where the data will be uploaded by users and where nextcloud also store some config files
Pavulon
Post by Pavulon »
Hi Outkastm
Is there any chance for an arm version of nextcloud?
Sending best wishes :)
F2-210
sorry but nor arm version for the moment
to much libraries to cross compile and without a NAS to test it will be very difficult
Re: [ Nextcloud ][ 23.0.2.0 ] Self-hosted productivity platform
up to 23.0.2.0
sanctimon
Post by sanctimon »
Thank you for the continued updates!
Any tips on how to make your version work with an apache proxy?
My public IP is pointing to a web server that is not sitting on the TNAS.
The server is https with SSL certificate and it's redirecting to http for Nextcloud on the TNAS. When TNAS makes a system and security check, it gives this warning:
You are accessing your instance over a secure connection, however your instance is generating insecure URLs. This most likely means that you are behind a reverse proxy and the overwrite config variables are not set correctly. Please read the documentation page about this ↗.
I have looked at the documentation and have adjusted all config files as best I can, but the message remains and Nextcloud Talk does not work.
