How to manually install 3rd Party Apps and the list with available apps
Re: How to manually install 3rd Party Apps
these are ones of the first apps, some adaptations are required to make the WebUI accessible on all systems and add some missing languages.
I will update them to latest version and will fix also the access to WebUI.
Already busy to compile ffmpeg
brunix86
Italy
Post by brunix86 »
{L_BUTTON_AT}outkastm
When the updates will be available, I need to remove and reinstall the apps?
Or it's enough to install directly the new version?
Thanks, I will wait for your updates when available.
My NAS Environment
  • TNAS F4-424
  • TOS 7.0.0777 (8GB System Partition)
  • 1x RAM Terramaster 8GB DDR5 4800 MHZ
  • 2x HDD Seagate IronWolf 12TB CMR [RAID1]
They are already available, just install the new versions.
Take care for MC you need to update also ModBase1 to latest version
brunix86
Italy
Post by brunix86 »
Thanks for the updates. I can confirm that all apps work fine now (see picture below).
My NAS Environment
  • TNAS F4-424
powerQ
Singapore
Re: How to manually install 3rd Party Apps and the list with available apps
Post by powerQ »
Do you have a plan to build a Gitlab TPK package? if yes that will be so great!
powerQ wrote: 11 Nov 2021, 23:46 Do you have a plan to build a Gitlab TPK package? if yes that will be so great!
I was speaking too fast... Due to the complexity of this app and the many required dependencies (apache/nginx, postgresql, ruby, go, Git, NodeJS, redis, Puma, GraphicsMagick etc) i recommand to install this using docker. If i need to make a .tpk, it will have around 1Gb and last time when i tried to manually install such tpk it was not supported by TOS.
powerQ
Singapore
Post by powerQ »
it is so sad to hear it. anyway, thank you for your reply!
powerQ
Singapore
Post by powerQ »
One more question, do you have a chance to make a wiki app that can run in TNAS? here are some popular opensource wiki softwares i learn from the web. https://www.fossmint.com/wiki-software-for-linux/
Give 3 as your preference order
