[ModBase1] Common libraries and tools for use by other modules
marchinho
Re: [ModBase1][1.00.11] Common libraries and tools for use by other modules
Post by marchinho »
outkastm wrote: 03 Feb 2022, 06:16 arm up to 1.00.01 (added unrar and nano)
Hello, sorry for pressing, when i try to use unrar i get this error
$ /unrar: /usr/lib/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by ./unrar)
Nano and the other modules are working fine
marchinho
Post by marchinho »
This is the lib content
I'll have a look this evening
try the latest version 1.00.02
marchinho
Post by marchinho »
It's perfect now!
Thanks for your great work ;)
mattb
Post by mattb »
Hey thank you for your hard work with this! I've just installed the aarch64 version 1.00.02 hoping to run screen or tmux, but they don't seem to be included in /usr/local/ModBase1/sys/bin. Have I done something wrong, or are they just not included yet?
Again, thanks for this package. It's really helpful.
Not included yet in arm package, but they will be on the next version
mattb
Post by mattb »
Brilliant! Thank you
arm version up to 1.00.03, added screen and tmux (to be tested)
mattb
Post by mattb »
Thank you for adding tmux and screen! I've not been able to get either to start though. As you mentioned that the apps still needed testing, I thought I'd let you know what I got:
Screen
Running screen gives the following error:
Cannot make directory '/run/screen': Permission denied
If I make this directory through sudo, it says the directory permissions need to be 777. When I did this, screen does run, but then immediately quits, leaving:
[screen is terminating]
I tried to find a logfile but failed. I'm not very familiar with screen, so I'm not sure if this is just something I'm doing wrong, like failing to pass options.
Tmux
This also won't start. With running tmux, there seems to be a locale problem. This is the result:
tmux: need UTF-8 locale (LC_CTYPE) but have ANSI_X3.4-1968
