[ Radarr ] Fork of Sonarr for Movies
TreyD
Re: [ Radarr ] Fork of Sonarr for Movies
Post by TreyD »
Radarr shows to have an update. How do you update the app without breaking it?
updated to latest version and added TOS5 arm version
PriestyUK
Post by PriestyUK »
Please can you update to 5.5.3.8819 — 12/05/2024
When you get time please :). Same for Sonarr
done
PriestyUK
Post by PriestyUK »
Cheers mate :D
jip1
Post by jip1 »
Hi Outkastm,
Thank you for the great work!
I see several updates for both Sonarr and Radarr, can I use the built in update functionality or will that cause issues?
Thanks!
J
sim667
Post by sim667 »
I'm having to reinstall radarr after reinstall TOS5 and it absolutely refuses to install. It just sits at 0% installation? Anybody got any ideas how I can get it to install?
Other community apps have installed fine, it just seems to hate radarr
GuyMoose
Post by GuyMoose »
Hi, I cannot get Radarr to enable or start. Just glancing at the start log it says there is an instance already running and it shuts down. If it helps, I’m also running sonarr4 and wondering if that’s maybe clashing? To confirm its not working, my ‘http://address:7878’ is not responding. Tried enabling, tried clicking start module, tried restarting, tried re-installing. No dice so far.
TOS 6.0.577
Radarr 5.9.1.9070.0
start_log.txt
Terrariaria
Austria
Post by Terrariaria »
jip1 wrote: 13 Aug 2024, 01:27 Hi Outkastm,
Thanks!
J
Same question,
Can I use the built in update functionality for Radarr?
No, this will brake the app. You can ask for updates on tmnascommunity.eu
