NTP Update:
Issues related to non sync in Windows and other issues may be device and/or configuration related. Previously I was testing using my F5-221. This is configured with 2 separate IP addresses (on same segment). I have switched the NTP to my F2-424 unit running a single IP address (bonded ALB) - just for laughs, naturally - and everything works! (With the -221 as server, I had tried the different ip addresses as target in the clients, but that didn't change anything as far as I could see.)
More:
F5-221 re-configured with Bond1 as Active backup. This configuration allows NTP service to run correctly.
F2-424 TOS7.0.1422 - 2x500GB nvme (P3) Traid, 2x6TB HDD (HGST) Traid Frustrated Beta Tester!!! F2-221, F2-425+ == Tos7.1 in progress (broken)!
upon reboot of the F2-424 the VMS app was not enabled, as a result the VM's did not automatically start, had to go in and enable the APP which then started the process of auto starting them
however the F2-423 worked fine and the VMS app was enabled automatically
F2-424 TOS 7.0.1536 F2-423 TOS 7.0.1536 F2-210 TOS 4.2.44 D4-320
ruzaj wrote: ↑29 Aug 2026, 04:42
online update not possible and why manual download speed is so slow? its not because of my download speed. I am located in austria.
Could you specify how slow it is? The slowness may be related to the CDN policies in your region. You might want to try again at a different time.
hi, I am currently on 5.1.73 on a F2-212 and want to update to the actual TOS 7 Version.
I have to ssd installed, will those files stay as they are or will the data be erased?
I am using the f2-212 for torrents and plex - so it's really important, that qbittorent server and plex media server work on TOS 7 - are those two apps working?
thank you for your help
zelluloid
zelluloid wrote: ↑30 Aug 2026, 18:24
The ARM version of TOS 7 supports Plex, but qBittorrent is currently not supported.
In addition, the TOS 7.0.1163 version provided in this forum post is intended for x86 models. For ARM-based models, you can upgrade to TOS 7.0.1114.
Please refer to the following forum post for more information:
Upgrade went fine from last version. "Operation Failed" still occurs when attempting to save any changes in the "Region and Time" are of settings. There is an existing support case with you already for this on the last version.
To help us accurately diagnose this issue and confirm whether there is an anomaly within the TOS system, we recommend scheduling a remote technical support session with our engineering team.
Please contact our online technical support via the link below. When reaching out, be sure to include this forum post link and your forum ID so our engineers can quickly reference your context and assist you directly:
Lex wrote: ↑02 Sep 2026, 22:28
The folder appeared again
Allegedly fixed in 7.0.1169
F2-425 Plus (N150), 16GB RAM, 2 x 500GB WD SN700 EXT4 RAID1, 2 x 3TB WD Red EXT4 RAID1, TOS 7.1 beta
F4-SSD, 16GB RAM, 4 x 4TB WD SN700 Btrfs TRAID, TOS 7.0.<latest>
