TOS 7.0.1105 (x86) Official Release Update
Re: TOS 7.0.1105 (x86) Official Release Update
Claus wrote: ↑08 Aug 2026, 20:09 Hi, I manually updated from version V804. Now I have the GlobalSearch problem too. After a restart, things look very good for a short while. However, after about 10 minutes, the process's resource usage keeps climbing higher and higher.
Hardware: F4-424 Max.
We are currently working on a fix. Please wait for a future version update.
Claus
Germany
Post by Claus »
Thanks for the personal reply. Don't stress about it. Regards.
nitzer71
Australia
Post by nitzer71 »
TMzethar wrote: ↑07 Aug 2026, 11:15
Additional observation:
After restarting the globalsearch service with:
systemctl restart globalsearch
the CPU usage immediately returns to normal and has remained normal since then.
So far, the high CPU behaviour seems to occur after a full NAS reboot. A restart of the globalsearch service itself appears to clear the issue without it returning during subsequent uptime.
This may indicate that the infinite loop is being triggered during the GlobalSearch startup/initialisation process after a NAS reboot.
F4-425 Plus | 16GB RAM | Intel(R) N150 | 3× 12TB HDD (TRAID) | 1× 1TB NVMe | 1× 500GB NVMe
Pe6yc
Post by Pe6yc »
F5-422 (bios MAPL0304V22)
after update TOS one of the volumes in D8 Hybrid is corrupted. Corresponding Storage pool after reboot wasn't mounted automatically.
I mounted it manually and Storage pull shows normal state but Volume still corrupted. The disk in D8 in normal state shows green.
Can I mount the volume by command line or make the volume back in normal state?
UPD: Reboot twice has fixed the problem. the volume is in working state
F5-422 (MAPL0304V22) - TOS 7.0.1536 (x86)
D8 Hybrid
snapsh0t
Post by snapsh0t »
Pe6yc wrote: ↑09 Aug 2026, 18:27 F5-422 (bios MAPL0304V22)
This may be an example of needing to leave the NAS alone for a few minutes after the update reboot as it needs time to get everything running. We've seen this reported here more than once recently.
F2-425 Plus (N150), 16GB RAM, 2 x 500GB WD SN700 EXT4 RAID1, 2 x 3TB WD Red EXT4 RAID1, TOS 7.1 beta
F4-SSD, 16GB RAM, 4 x 4TB WD SN700 Btrfs TRAID, TOS 7.0.<latest>
rfbjr
Post by rfbjr »
Been away all week. Just updated all three devices, no issues. About all I'm going to do for the rest of today. I'll slowly check things out for the next few days.
F4-424 Pro (x2) and F4-425 Plus at 7.0.1536
F6-424 Plus at 7.1ß
D4-320 & D4-SSD
rfbjr
Post by rfbjr »
Does Phase 1 actually fix what's listed in the announcement or does that happen in Phase 2?
Just trying to follow along, still in vacation mode.
F6-424 Plus at 7.1ß
D4-320 & D4-SSD
EriChan
Post by EriChan »
nitzer71 wrote: ↑09 Aug 2026, 09:14
Thanks for your feedback. We are actively working on a fix and will include it in a future version update
EriChan
Post by EriChan »
rfbjr wrote: ↑10 Aug 2026, 06:22
Yes, Phase 1 includes all the fixes and features listed in the announcement!
The only difference between the two phases is the distribution method:
  • Phase 1: All fixes are included right now. You can manually download the update package from the forum and install it immediately.
  • Phase 2: The exact same update will be pushed automatically as an online OTA notification in your TOS in about a week.
Enjoy the rest of your vacation!
EriChan
Post by EriChan »
This kind of behavior is typically related to a disk array mounting issue during system startup. To help us pinpoint the root cause and prevent it from happening again, we recommend enabling Debug Mode:
Enable Debug Mode: Go to TOS Web UI > Help & Support > Debug Mode and turn it on so the system can record detailed logs during abnormal events.
If the issue reoccurs:
  • Restart the device first.
  • Download the debug logs and send them to our technical support team at [email protected] and attach the forum link and your forum ID as well.
  • If possible, please note the exact timestamp when the issue occurred, as this will greatly assist our team in troubleshooting.
Note on Log Downloads: The debug package contains three files (kern.log, syslog, and atop_log). Due to their file formats, your web browser might block them. If you notice any missing files after downloading, please check your browser's download manager to allow and complete the download.
